wastegate fitting
Old Dec 15, 2009 | 01:27 AM
Blue_TC_Man's Avatar
Default wastegate fitting
ok so I have an exhaust leak where my wastegate connects to my dumptube, the wastegate is a tight fit to say the least, and I need to figure out how to seal it. Is the high heat copper rtv sealant my best bet?
Old Dec 15, 2009 | 01:59 AM
gingles's Avatar
you dont really need a gasket there since your dumping to atmosphere....but if you want i wouldnt use the copper....it failed for me
Old Dec 15, 2009 | 02:51 AM
crush02342002's Avatar
open or recirq? what size wastegate? I would get a new crush gasket, they can be found almost anywhere....dezod,p-tuning, atp turbo, ect.
Old Dec 15, 2009 | 02:54 AM
bigBOAT's Avatar
same with me with the coper ones i got some new ones from dezod so well see how it goes
Old Dec 15, 2009 | 04:51 AM
well it is recirc i guess it goes back into the exhaust im not too worried about it since people do run open wastegates but i just wanna make sure its not gonna mess with anything
Old Dec 15, 2009 | 05:05 AM
if you are recirq then it needs to seal, if it doesnt then your wideband may show lean
Old Dec 15, 2009 | 03:38 PM
paul_dezod's Avatar
Scionetics
KAD
It's leaking at the WG outlet? Have you used the gaskets for the gate like this?
http://www.dezod.com/pd-tial-stainle...dividually.cfm
Old Dec 15, 2009 | 03:52 PM
got ya,
and yes thats the gasket that came with my wastegate
Old Dec 15, 2009 | 07:26 PM
paul_dezod's Avatar
Scionetics
KAD
got ya,
It's leaking past the gasket? You can try copper RTV
Old Dec 15, 2009 | 07:40 PM
sure is, thats what I though I would have to do
Old Dec 15, 2009 | 09:22 PM
highvoltage1's Avatar
I would maybe take some sand paper and try and lightly sand the manifold side where the wastegate mounts. Maybe its slighty uneven? Some surface defintely isnt level cause the gasket should work even if slightly off.
Brammi
Nov 13, 2016 03:46 AM
BlackKnight
Sep 15, 2015 06:42 AM
my06tc
Jun 25, 2015 12:18 AM
skruff
12
May 28, 2015 03:00 AM
SpaceCaptain
May 11, 2015 06:24 PM
