08 tC fuse type
Old Sep 25, 2007 | 07:23 PM
stc08's Avatar
Default 08 tC fuse type
does anyone know if the 08 tC's take ATO/ATC Fuses, or are now using mini fuses, just wanted to be sure before buying, wish i could check myself but my cars getting a custom sub and box put in
Old Sep 25, 2007 | 07:27 PM
STNC's Avatar
The use Low Profile Mini Blade Fuses, available only at your dealer.
Old Sep 25, 2007 | 07:41 PM
stc08's Avatar
i wanted to put in an add-a-circuit to my fuse box for my cathode intall, i was going to get the add-a-circuit fuse holder for mini fuses, so using just regular mini fuses into the add a circuit wont work..sorry if i was not clear the first time
Old Sep 25, 2007 | 08:45 PM
stc08's Avatar
this is what i wanted to add to my fuse box
Add-A-Circuit Fuseholder For Mini Fuses
This ingenious device allows quick and easy installation of additional accessories without the need for splicing. For use with Mini Knife fuses. Includes installation instructions. Max rating: 10 amps.
can someone please tell me if this set up will work, after this is put into the fuse box, i am told i just put in the regular 10amp mini fuse into it, and also was told it does not have to be the dealer fuse, but maybe the dealer fuse will fit
Old Sep 25, 2007 | 08:52 PM
KINGxOFxSKA's Avatar
Unique Scionikz
^^^ that will work. I'm using two of em on mine.
Old Sep 25, 2007 | 08:58 PM
stc08's Avatar
so after i put this into the fuse box i can put in any 10 amp mini fuse into it, it doesn't have to be the dealer one right, and also just wondering cand the factory fuse also be pt in
Old Sep 25, 2007 | 09:26 PM
STNC's Avatar
Yeah, i have one of those (i just never needed it), but it will work
Old Sep 27, 2007 | 11:37 PM
SquallLHeart's Avatar
looks like the low profile mini fuses won't fit into the add-a-circuit itself..
you'll need regular mini fuses at that point... which at least are much, much easier to find.
Old Sep 27, 2007 | 11:44 PM
stc08's Avatar
thanks thats exactly what i did, i bought today the mini add-a-circuit, and the 10 amp mini fuses that go with it
Old Sep 28, 2007 | 02:11 AM
CarbonXe's Avatar
I got some mini fuses from Radio Shack and they fit just fine, they're only about 1-2mm taller.
yupinmytC
22
Jul 27, 2024 07:08 PM
alexdrummerr30
Sep 8, 2018 12:18 PM
Darrenohooligan
Sep 26, 2015 07:21 AM
DannyBoy65
Sep 21, 2015 06:23 PM
spharr62
Sep 20, 2015 01:44 AM
