Car Audio Learning
Old Feb 7, 2008 | 12:37 PM
z-lite's Avatar
Originally Posted by Simple_Satisfaction
k i get it....
is it better to get a 4ohm dvc sub and have it to a 2ohm amp or 2ohm dvc wired to a 4ohm amp?
reason being i want to run a single 500w amp to each is because i was told that running 1000w (2-500w subs) on a 1ohm amp is unstable; if this is not true then i will try and run it to 1 amp instead of 2....?
There are a lot of big name companies who have 1 ohm stable amps, some that are cheap may not be stable and turn off or fry itself. It's easier to get your amp first and then figure out what voice coil configuration you need than finding an amp to fit your sub's impedance configuration
Old Feb 7, 2008 | 07:52 PM
Simple_Satisfaction's Avatar
shout I run
2- Phoenix Gold 500w Ryval amps
-or-
1- HIFONICS BXi1606D Class D Mono smp
those are the only two amps that i found to fit the ohm needs within my proce range..... which is better?
Old Feb 7, 2008 | 08:19 PM
z-lite's Avatar
Hifonics will work and I would recommend 1 amp than 2. Generally, it's better to use 1 amp for multiple subs than 2 due to the fact that one sub might be moving at a different pace than the other sub if you have the signal between the subs be off due to the wired polarity, the gain adjustment, bass/EQ settings set on one amp but not the other, etc
Old Feb 10, 2008 | 07:11 PM
ok i have everything in checkout and ready to go but what all do i need to have the head unit hooked up?... i went with sonic electronix so they give me a free wiring harness and installation kit, but do i need anything else or no? this is my final post till the build so i am kinda anxious to get everything.
Beesh
Jan 9, 2015 06:30 PM
minter66
Dec 15, 2014 01:45 PM
Nargrakhan
Scion iQ ICE & Interior
Dec 10, 2014 06:10 AM
carid
Nov 21, 2014 11:00 AM
tC_Normo
Oct 22, 2003 07:20 PM
