CLOSE LOCK!
Old Apr 9, 2008 | 08:45 AM
djct_watt's Avatar
Team Sushi
AMPS=watts/volts, so 110 watts (if you run 2x 55 watt bulbs) / 12volts = 9.16Amps.
Make sure that the switch is rated to at least 10A, as many interior switches for cars are only rated at 5A. If you run a 5A switch, you'll have a melted switch sooner or later. And if you're running 100 watt fogs (I've seen a lot of aftermarket bulbs at this rating), you'll be running at 16.67A, so you'll need at least a 20A capacity. Good luck there! Sure, ghetto rigging may get stuff to work temporarily, but there's no telling how long it'll last (or how lucky you'll be).
Old Apr 10, 2008 | 08:29 AM
UNiT_xEr0's Avatar
DelMarVa
ok i wired his car today with a 15amp switch and put a fuse link to it. everything worked out well. they fired right up. then i adjusted the fogs and now they are lined up. enjoy mice! you gotta see my yellow vrd hids! i just tested it and its crazy sick!
Old Apr 10, 2008 | 08:30 AM
UNiT_xEr0's Avatar
DelMarVa
o btw i used the same guage wire as the power wire on the fogs harness. only if it was red so it would match with your engine bay... sorry about that mice!
Old Apr 11, 2008 | 06:28 PM
MicE's Avatar
Ok.. everything works great! guages and vrd fogs... "the correct way" thanks unit and djct watt!
Please CLOSED LOCK
yupinmytC
22
Jul 27, 2024 07:08 PM
user9430961
Sep 24, 2015 01:09 PM
user9430961
Sep 15, 2015 03:16 AM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
BlingSlade
Sep 5, 2015 08:52 AM
