Componant Speakers
Old Aug 9, 2009 | 01:19 AM
amp0804's Avatar
Default Componant Speakers
Its about time I do my audio set up in the car. Here is the deal, ive been installing audio systems for a couple years now in my free time but when it comes to higher end brands specifications and so forth im lost.
I'm looking for very good components to run in the tC amped. Ive been looking into CDT online and also the new ED e9.65i's, definitely open to other options but I want to keep it under 300 for sure just for the speakers.
If anyone has advice or input please I would like to know, also where to purchase CDT products online.
Just want to do a install on the front doors only and keep the rear empty so the best bang for the buck is what im looking for
Old Aug 10, 2009 | 11:13 PM
CameronTX's Avatar
The best bang for the buck.... I'd suggest Phoenix gold RSD's.
Old Aug 11, 2009 | 01:18 AM
BZinn1's Avatar
For under $300.......what type of music you listen to........and how do you like the sound,do you want lots of midbass,lots of treble out of the tweeters,do you like the laidback sound,or the inyour face vocals and such.......also what you running for amps and subs,this also helps to get a system taht will work together......
Old Aug 13, 2009 | 06:38 AM
jobunaga's Avatar
check out this comparison review from ctuchfield:
http://www.crutchfield.com/learn/rev...oundtable.html
the infinity kappa perfects were the best all around, but not the best in each music category. so like BZinn1 said, it's really your music preferences that are going to determine what set of component speakers you should buy.
Old Aug 13, 2009 | 06:02 PM
BZinn1's Avatar
Exactly.......my eD 6000s are awsome comps,lots of midbass,clean vocals,and they take the power like crazy,but the tweeters for them suck......they are harsh,and even at -3db on the crossover and wired out of phase they are still in your face loud......changing out to a set of Seas this winter.
Old Aug 13, 2009 | 08:31 PM
nodsetse's Avatar
Where are you going to mount them? If you're serious about SQ, then build some kick panel enclosures. $300 speakers in the stock location is a waste of money imo, unless you implement appropriate delay on the driver's side, which ruins the sound for the passenger...if you care about that.
I'd rather have stock speakers in kick panels that the best $300 components in the stock door locations.
Old Aug 13, 2009 | 08:38 PM
BZinn1's Avatar
yeah the tC is hard to SQ the comps,I got my tweeters in the kicks and wish I was good enough to glass a set of pods in the kicks,I amy pick up a set of kicks to practice on though,how hard could it really be......but then I wold switc up to some DSL.
Old Aug 14, 2009 | 03:16 AM
amp0804's Avatar
I listen to pretty much everything but country and techno...85-90 percent of the time its hip hop. The speakers should have great mid bass and vocals should pop when necessary nothing dramatic. I want it to be be complete front stage and not using backseat speakers at all. I was thinking the ed 9.65i + nine.2 + my avic d3
I want to put the tweeters in the kick panel or mount them somewhere more appropiate then the doors.
Old Aug 14, 2009 | 03:30 AM
BZinn1's Avatar
that will be a good set up,the tweeters in the 9.65s are not as harsh as the older ones........also an important part to the set up is sound deaden the doors,I got a layer of the liquid and then 2 layers of the .080 on the skin then a layer of it on the inner panel that the door panel goes on,door is mostly sealed up and the sound is a lot better midrange wise.
Old Aug 14, 2009 | 03:58 AM
amp0804's Avatar
How should i go about cutting the holes for the tweeters in the kicks? Is there a rubber grommet supplied to go into the hole where the tweeter sits in?
Old Aug 14, 2009 | 03:59 AM
Murphys_Law's Avatar
alpine type Rs
Old Aug 14, 2009 | 04:45 AM
BZinn1's Avatar
I cannot remember waht exact size the hole for the tweeters are but I thouhgt it was 2",get a 2"hole cutting bit for a drill at home depot,bring the tweeter with you,it is going to make sense what size to get when you take the tweeter with you and size up the trim ring to the hole cutter bit.
then to cut the hole just attach cutter to drill and pick a spot,drill them not attached to the car and make sure the spot you pick to drill is not hindered from behind in the car......
I had one that is snug in the hole and the drivers side I had to epoxy it a bit to keep it snug....my drilling skills suck......lol
Old Aug 14, 2009 | 10:34 PM
amp0804's Avatar
Yeah i was figuring thats how you do it, I have all the tools I do alot of carpentry for side jobs thanks alot for your help ill keep this updated planning the install for this weekend if i get the rest of the wiring i need.
Old Aug 15, 2009 | 05:41 AM
amp0804's Avatar
Would a 8g amp wiring kit be safe to use with the nine.2 when im only amping 1 set of comp. speakers?
Old Aug 17, 2009 | 06:52 PM
nodsetse's Avatar
^Yes, 8awg is adequate for a single nine.2 putting out 100wpc into a 4 Ohm component set. However, it wouldn't be enough if you add another amp to power a sub, so you might consider going with 4awg instead.
mischman
Sep 15, 2015 03:38 PM
kslim619
Aug 18, 2015 01:22 PM
carid
Aug 7, 2015 11:32 AM
sciongirl13
Scion xA Aero & Exterior
Jul 22, 2015 02:28 AM
