Constant on turn signals (STILL FLASH)
Hey SL,
Figures I would post my wiring diagram for a little project I did over the weekend. Someone told me about some cars in PR that have their turn signals on all the time like parking lights. After some research I drew up a schematic and built the circuit.
TLDR; IT WORKS! lights on with ignition, and turns/hazard still flash!
This should be a rough idea of what I did.
PROCESS:
I had to disconnect the FLASHER RELAY from the INSTRUMENT PANEL:
This is located behind the panel below your switch panel to the left of the driver side.
Similar to a piggy-back on an ECU, I made my own wires that ran from the flasher relay back to where it plugs in. All lines ran straight, except the 2 lines (green and yellow) which the polarity is turned around using a automotive relay.
WILL POST PICS SOON OF WIRING INSIDE CAR.
Hope that this inspires so of you more technical and handy guys( and gals) to do to your own car.
PROCESS:
xBSciontist
Jun 18, 2019 03:06 PM
randomsuper
20
Jun 13, 2015 10:56 AM
