DIY: Upgrade the bazooka sub and Amp (tons of Pix!)
I have done what others have said is impossible! Behold:
Sizing things up.
The Gear.
Step 1: Remove the stock sub.
The old Amp.
Will it fit?
Step 2: Test Fit.
Step 3: Remove the box.
The stock wires are nicely labeled.
Step 4: Relocating the wires.
Step 5: Run the wires through the box.
Step 6: Wire it up. (I chose to use the speaker inputs over the RCA's from the head unit preamps since I already have the adapter up front.)
All Finished and ready to slam, now I need to track down all the rattles this has uncovered...
Sizing things up.
The Gear.
The old Amp.
Will it fit?
Step 2: Test Fit.
Originally Posted by bronxblaza117
hows that sound?
and they said it couldnt be done!!!
nice job, placement of amp is aite, i woulda hid the wires
also just out of curiosity, why didnt you mount it in the cargo area underneath the trunk panel?
i did this with a kicker sub a whiles back-much better than the bazook setup. the bazooka's amp is the size of a friggin palm pilot. the only thing i did differently was to have the port hole sealed up. there's a lot of space inside that enclosure and i wanted to tighten up the sound a little bit.
If i try this with the stock HU would it be worth it????
I would like to do something like this but if its not worth it than ill leave it the way it is!!!
Would the stock HU be able to handle the new amp and sub??? Thanks...im a newb when it comes to audio stuff, forgive me!!!
the thing is deep as hell and has alot of space, but i still wouldn't recomment putting an amp inside the enclosure-first off, there's not a lot of space, second, there's gonna be a lot of rattling and vibration from the subwoofer, which may or may not mess up the amp. it might not cause any problems, but who wants to chance it.
does the cover still go on or is the sub too big... haha imma do this when mine blows too =) or when i feelin that i need more bass.... which might be soon.... time to crank it up!
it will still be an improvement regardless, you can try to contact SCIONtific_tC, he has a stock deck and two 12" type S. But hes only pushing the amp 1/4 of the way and its way too much already.
I'd definitely seal up the port.... that enclosure SHOULD be tuned to the t/s parameters of the bazooka sub.... by swapping the sub out, it'll affect the sound.... sealing the box will allow it a larger range to attempt to accomodate whatever sub you decide to put in there...
