HID low beam issues
So. I have an issue with my low beam hids. I have hids in my foglights.(not sure id that makes a difference)
They just randomly quick working one day. No flashing, no trying to come on. Just nothing. And one day, when I flipped my lights switch on, they did work. Until I shut my car off. Next time I went to turn them on, there was nothing.
My foglights still work, make it possible for me to drive at night.
Any ideas would be useful!
im sure someone will say it if I don't... you checked all the connections and looked to see if they have any corrosion? Both low beams or just one? I had an issue with high beam flicker and couldn't solve it. It was really strange. I replaced the whole shooting match (have yet to install tho). Had a low beam go out once and unplugged it to check and hooked it back up, never had another issue
Sent from my DROID3 using Tapatalk
If you're using your stock headlight harness, check your headlight fuses. I've had mine blow out before and cause neither of the headlights to come on. There are a total of 4 fuses.one for each bulb.
TheTripleC
Jan 4, 2015 06:46 PM
