my first lighting project
Originally Posted by yellowxboy
oh yeah, how'd you mount the cathodes under your car? did you have to lift the car or was it really easy? what did you use? i have 3 pairs of leftover white cathodes i wanna mess with :D
I also ran a ground wire from one side to the other ground wire, that way when one door is open both sides will light up. I hope this helps
man.. i always screw up. haha
i'll try getting rid of the grounding switch, hopefully that will solve my dome light problem.. crap its so weird w/o the dome lights. hahaha
plastic cover over where the steering wheel rod enters teh egine bay.. hmmm, i gotta see where that is at. if you could take a picture it would help me (i'm retarded. haha)
oh btw, i didnt do the other switch where i can manually turn the cathodes off ... i was trying to figure out how to fix the damn domes for the longest time :X
i added the switch for the ground. its weird.. the dome lights dont work at all. reguardless of door open or closed. i cant even manually turn them on. all the dome switches dont work. its so annoying..
so its either 1) have control over the cathodes and being albe to power them up while driving BUT lose the domes or 2) have control of the domes but not able to turn on the cathoes w/o opening the door
yellowxboy, try following what people have been doing to install puddle lights.
https://www.scionlife.com/forums/viewtopic.php?t=117628
I tried it with an extra cathode tube I had laying around. Your lights will turn on when you open a door and then fade out when you close them. You can also add a switch so if you get tired of that you can turn it off.
I have to re-route all cathode tudes and leds so that they will turn on when I open my door. I currently have a cathodes in each door pockets, rear seat pockets and two under each front seat. I have a leds in the front and rear cup holders and air vents.
I setup two other cathode tubes in back hatch to turn on when I open the hatch by connecting them to the little light in the trunk.
i'll try to re-route n finally finish this whole mess on friday or something :X i should be getting my megan header soon! i cant wait!
TheTripleC
Jan 4, 2015 06:46 PM
