Need info about wiring sub and amp
Well i plan on getting the 6500s, with the kenwood dvd unit, and no rear speakers. seems the kenwood unit does do 5.1 so it works out fine with just the front speakers being replaced. I am looking for an amp, to wire to the door speakers and give em juice I was thinking about a rockford fostage 200 amp i can get for 70. think that will cut it? also can i wire up the factory rears to that amp as well or woud it be too much for them.
Cliffs: need amp help with speakers
What's the model of the amp? RF's naming confuses me
Honestly, one speaker(or mid/tweet)/channel. Fronts on a 2 channel amp, rears on the HU...but don't plug them both in one set of amp channels
If that amp does 100x2 @ 4 ohms, yes, should be awesome.
sorry was on my sidekick before so it was a short responce. the spec of the RF 200s are:
# stereo, bridged mono or Tri-Way output
# 100 watts x 2 at 2 ohms
# 200 watts x 1 in bridged mode
# MOSFET power supply and output devices
# 80 Hz low-pass, 120 Hz high-pass crossover, 12 dB/octave
# 0/6/12 dB selectable bass boost at 45Hz
and the Kenwood KAC-848 are:
Key Features
Amplifier Type Multi Channels
Bridgable Bridgable
RMS Power at 4 Ohms 50 W x 4
RMS Power at 2 Ohms 75 W x 4
Performance
Frequency Response 5 Hz - 50000 Hz
Signal to Noise Ratio 100 dB
THD at Rated RMS Power .08 %
Crossover / Equalizer
Low - Pass Frequency 50 Hz - 200 Hz
High - Pass Frequency 50 Hz - 200 Hz
Key Features
Bridgable Bridgable
Performance
Well, the RF at 4 ohms stereo is going to be around 70ish watts knowing RF's ability for under rating
The Kenwood should be around 150x2 @ 4 ohms when bridged. I'd go with the Kenwood bridged if those were my 2 options for the 6500s ;)
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
stillcole
Scion tC 2G ICE & Interior
Apr 6, 2015 03:42 PM
TheSilencerTC
Feb 24, 2015 04:56 PM
