New member with a key remote question
Hi all, I tried to find the introduction thread, but can't seem to locate it. Anyways:
My name is Mike and I hail from Burbank, Ca. I do not own a Scion Tc, but my brother does. I'll be on here to ask a couple questions now and then such as this one
Which remote or key fob will work for a 2008 Scion Tc? I went to the stealership today and the only remote they said will work for the car is the remote with the key built into it. Can any other remotes for previous Tc years work for the 08? I figured the directions on programming the remotes work for all cars anyways, right?
Also, the key will need to be cut. Can I just take it to any other shop and make a copy of it for a few bucks? I dont wanna spend $250 at the dealers, and found one off ebay for like $60 shipped. Let me knows. great to be here =]
I wonder why programming like 04 scion remotes wouldnt work for the 08? If they have the same instruction for programming them, unless both cars have different chips for those certain key fobs
Well if he has a key that doesn't work, spending $20 and transferring the current key's guts to a new one makes more sense than spending hundreds at the dealer.
So I guess the question is then, why the replacement key?
(and yes, I believe the earlier keys are slightly different in some way)
Programming instructions should be the same throughout the years but that is only for the keyless entry part of it. There is also a transponder chip in each key that comes with the car that communicates with the car when the key is inserted - the car will not start without this chip.
there is no such thing as a universal remote for keyless entry. each one runs at different ranges.
to get another immobilizer chip... you'll need to spend the money at a dealership.
btw, the non-remote key does have a chip inside of it.
the immobilizer chip must be programmed for the ECU to recognize... a process that only dealerships and very, very, very rare few select specialized locksmiths can do.
looks like you'll be spending $250.
Either way, a friend of ours won it at an auction for $5K and the sold it to my bro for $8k with only 25k miles. So we would have no way to contact the original owner of the car.
I noticed you said up above programming should be the same for keyless entries for all years. Do you think it would be possible to use an earlier keyless remote from another scion tc on this one?
wwotr
03-28-2015 01:47 AM
