Problem after HU install
Old Nov 9, 2006 | 05:28 PM
crowboy164's Avatar
Default Problem after HU install
Hey All, I've searched the forums, and saw people with the same issue as myself but no resolutions posted.....Here's what up
I upgraded my HU last night in the car (removing negative ground wire first before i get flamed) and everything went very smoothly. After getting it reassembled, I went for a drive and noticed that the backlight for the HVAC controls and the clock are not lit any longer. I tried disconnecting the dimmer connection between the factory side and the new HU and still no luck. When the headlights are off it works, when they are on no worky.
I can't take it in as "under warranty" because it's expired on my 05. 60,000 miles :-( any advise would be helpful.
Old Nov 9, 2006 | 05:37 PM
Garage1217's Avatar
did you hack into the stock harness or use an aftermarket harness to do the install..?
Old Nov 9, 2006 | 05:55 PM
crowboy164's Avatar
used an aftermarket harness from Best Buy. [/quote]
Old Nov 9, 2006 | 06:13 PM
Garage1217's Avatar
Hm..... Interesting... does your gauge cluster lite up..?
Old Nov 9, 2006 | 06:34 PM
crowboy164's Avatar
Yeah. the guage cluster lights up no problem at all and dims properly. I saw this post
https://www.scionlife.com/forums/vie...ight=backlight
and tried contacting "Grymson" to see what happened but had not heard a reply yet. Anyone? it's not a fuse since it gets light when the headlights are off.
Old Nov 10, 2006 | 02:13 AM
L8u8k8e8's Avatar
*Edit - Reread, nevermind my origional post
That is one wierd problem, sounds like some wiring is messed up
Old Nov 10, 2006 | 02:16 AM
rrimportracer's Avatar
if the ac works check your fuses both inside and out for a burnout
Old Nov 10, 2006 | 04:16 AM
crowboy164's Avatar
I just figured out what did it on my car. Was going back over thr wiring with a fine tooth comb and didn't realize there were 2 ilumination leads on the toyota harness. 1 positive and 1 negative.... not playing close attention when wiring i presumed one was on the HU since i'd never seen 2 on a factory harness and wired them together. will check my fuse box in a few and see what i blew.
Old Nov 14, 2006 | 03:30 AM
crowboy164's Avatar
went through the fuses near the clutch and under the engine and was unable to find anything wrong...does anyone know which relays might control the back light for the hvac, i assume it would be different then the one for the instrument panel as that still works properly.
Old Nov 14, 2006 | 03:40 AM
L8u8k8e8's Avatar
https://www.scionlife.com/tech/elect...rical_tc05.zip
Sticky at the top of this board, one of the PDF files has all of the relay locations.
Its called 020-031 relay location.
It shows you all the relays.
As to which relay... im not sure, and I dont have enough time at the moment to look through the electrical stuff.
I'll look tomorrow and see if I can find it for you, in the mean time that electrical stuff might help you.
Tomorrow
Old Nov 14, 2006 | 01:24 PM
L8u8k8e8's Avatar
Okay, if I am reading this right, the interior lights for the guages and HVAC are linked to a combination meter, not a relay.
In the 082-085 illumination PDF you can see the junction on the second page called A/C control assembly and the white cable attached to it goes to a junction connector, the problem either lies with the junction connector there, or with the combination meter attached to it.
My guess is that its that combination meter, and I have no clue where this part is in the car, or where you could get it...
So, I think you'll have to go to the dealer to get this fixed.
*Edit - I thought more of the problem, in the same PDF file as above it could also be the combination switch that switches with the light control switch.
Old Nov 22, 2006 | 07:03 PM
crowboy164's Avatar
Still lost sadly enough, i really can't figure this one out
Old Nov 22, 2006 | 11:59 PM
L8u8k8e8's Avatar
Really, the only way I can think for you to get this fixed is through the dealer. I dont know of how you will really be able to figure it out on your own. I doubt I could get it.
So, either the dealer, or just live with the problem, thats all I can think of.
Old Nov 25, 2006 | 04:20 PM
Zangetsu's Avatar
Have u been able to fix the problem?? I'm having a similar issue with my car as well....
randomsuper
20
Jun 13, 2015 10:56 AM
missing_image
Feb 7, 2015 07:18 PM
EvalEvan66
Jan 27, 2015 02:26 AM
EvalEvan66
Jan 16, 2015 08:34 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
