rockford fosgate 360.2
First I apologize if this is a thread already I tried searching.
My intention is to keep the factory HU and use a 360.2 to do the legwork for my amps. Along with a stealth installation I'll maintain a factory look.
Anybody here use a 360 with their stock HU and if so did it work as well as I think it will? Thanks!
While I haven't used it, I'm certain it'll meet your requirements as stated.
If you don't want to spend so much, there are much less expensive devices that will provide the basic functionality you need.
I'm using the Scosche SLC4, which provides a quality signal to my amps and is currently just $20.
I don't own the 360.2, but we've had experience with it at work and customers have told me about their experience with it. Bottom line is, it's an awesome unit, but be prepared to spend some time programming it. One guy didn't get it right for 3months.
im excited to get it, hopefully by the end of september i'll have everything I need and I can start building my system
thanks for the info guys
I just need to get the 360, front components, speaker baffles, and a wiring harness or two so I don't strip any factory wires and I'll be ready to build.
hopefully by then i'll make up my mind on a sub mounting location
EDIT: I have a laptop with bluetooth and I already played with the software a bit, yes there are too many tuning options lol
Strictly Scionized
since you are doing the 3sixty.2, you might as well run it to the full potential and run the fronts active. If you don't plan on running anything active and just want a line converter just get the 3sixty.1
i just installed the 360.2 in my 09 xb with the stock scion navi unit. holy ____ theres alot of tuning to do. rf tech line though is on it, answer right away and they are pertty helpfull. im still undicied if its worth the 700 bucks though.it may be in th eclassifieds soon so keep an eye peeled!!!
airmankevin1
02-14-2018 01:23 PM
braids
9
04-20-2005 03:22 AM
