SQ10 rattle
Theres my eD SQ10 has started to kind of produce a rattling or flapping sound when it initially hits. There hasnt been a decrease in volume so i dont think its blown, I actually just think that the silver part on top is loose. Is there an easy way to fix this? I'd rather not send it to them because then I'll be a month without bass.
Originally Posted by BZinn1
check the cone cover,they can come off,seen a couple on here that came loose,but can be epoxied back in place easily enough.
....whats this cone cover you speak of
I had the same thing happen to me with my SQ10. I called them up and they had me super glue the silver cover back on which only helped for a day or two.
After that they sent me a new sub with a prepaid return label for the old one.
Originally Posted by x_Batman_x
...run a thin bead of silicon around the edge and wipe away excess?
Most silicone puts off a massive amount of toxic fumes while it's curing, and those fumes are so strong they can actually cause the speaker's adhesive to come apart (they use glue in various places during manufacture), effectively destroying the speaker. This is why you need to wait several days before installing a speaker in an enclosure that's been sealed using silicone.
So what adhesive should a person use for speaker repair? They happen to make one;
http://www.parts-express.com/pe/show...number=340-076
It's strong, safe, and can be used anywhere, during cone replacement, dustcap replacement, surround repair, spider joining, etc.
steeze69
May 24, 2021 02:57 AM
