System
Old Oct 31, 2006 | 07:41 PM
  #121
SCI_TC_GUY's Avatar
that's because I thought the numbers would tell me single or dual VC.... being that they're 8ohm, I'd say they're SVC...
next, find that model number on the amp
Old Nov 1, 2006 | 12:15 AM
  #122
Scigon7's Avatar
would u kno how much power the subs could handle? without knowing the amp size?
Old Nov 1, 2006 | 11:14 AM
  #123
SCI_TC_GUY's Avatar
well, the "C12" indicates it's a Kicker Comp 12" sub... I looked up that information and they'll handle 150RMS each...
I still need to know the amps model number to see how you need to wire it.
Old Nov 1, 2006 | 01:29 PM
  #124
Scigon7's Avatar
weird...my boss said they were 10's
Old Jan 26, 2007 | 06:28 PM
  #125
Scigon7's Avatar
http://www.edesignaudio.com/edv2/pro...roducts_id=225
are those the rca cables i need to run my nine.2 and nine2x amps?
Old Jan 26, 2007 | 06:49 PM
  #126
SCI_TC_GUY's Avatar
yes, one RCA set per amp...
Old Jan 28, 2007 | 02:20 PM
  #127
Scigon7's Avatar
another quick question. if i am keeping the stock headunit. can i get a line out converter from ED or am i better off going to another store and buying one? and which one do i need for my 2 amps
Old Jan 28, 2007 | 02:28 PM
  #128
nebster's Avatar
don't keep the stock headunit lol. spend 200 bucks and get a decent aftermarket one. it will be your best decision ever.
Old Jan 28, 2007 | 02:29 PM
  #129
Scigon7's Avatar
my parents wont let me buy a new headunit cuz i got the ipod upgrade...so i need to keep the stock headunit for now..
Old Jan 28, 2007 | 02:34 PM
  #130
nebster's Avatar
ahh that sucks. then yeah just get a LOC from eD. if you have any questions click the live support button on the top of eD's site and they'd be glad to help you out. i'm not very good with LOC's because i've never used one.
Old Jan 29, 2007 | 10:16 AM
  #131
Scigon7's Avatar
do i need 2 locs because im running 2 amps...im not really sure can anyone help me?
Old Jan 29, 2007 | 11:23 AM
  #132
SCI_TC_GUY's Avatar
There are some LOC's that do 4 channels (for one 4 channel amp or 2 2channel amps).... just look for 2 sets of RCA output on the LOC or do as Ben stated and get on eD's live chat - they'll get you lined out.
Old Feb 3, 2007 | 03:24 PM
  #133
Scigon7's Avatar
what happened to all of the forum discounts???
Old Feb 5, 2007 | 12:18 PM
  #134
SCI_TC_GUY's Avatar
They ended Feb 1st.... but everything gets the 5 year warranty instead of the 3 year....
Old Feb 5, 2007 | 09:56 PM
  #135
Scigon7's Avatar
i bought the duel amp kit from ed....can some one tell me how to hook it up...none of the wires are long enough to go from the battery to the amp in my trunk??
Old Feb 6, 2007 | 12:44 PM
  #136
SCI_TC_GUY's Avatar
You hook the biggest, longest cable to your battery via one of the supplied ring terminals, cut the cable within 18" of your battery connection, install fuse holder at that spot, run the remainder of the cable back to the back to the distribution block where you hook the cable that's thinner than the power cable to the dist. block and run it to your amp... then run your ground to a grounding spot, run RCA's to HU along with remote wire to HU, then speaker wire to subs / speakers.... put fuse into fuse holder by the battery and fire it up...
Old Feb 6, 2007 | 01:19 PM
  #137
Scigon7's Avatar
why do i need 2 distribution blocks then?
one for ground? one for power? or both for power?
Old Feb 6, 2007 | 01:29 PM
  #138
SCI_TC_GUY's Avatar
If you've got 2 dist blocks, then one is for ground and one is for power... There should be 2 pieces of 4ga wire (or 0ga if you got the 0ga kit).... one will go to the battery and the shorter will go to the ground spot.... then distribution block to the amps with the smaller gauge wire...
generally, blue or red is for power and black or silver is for ground....
Old Feb 6, 2007 | 01:31 PM
  #139
Scigon7's Avatar
but the 4 guage wire is only 5 feet long for ground...and other is 10feet...i dont think it will reach to my amps ...wil it?
Old Feb 6, 2007 | 01:35 PM
  #140
SCI_TC_GUY's Avatar
The ground 4ga only needs to go to a spot of bare metal (no paint or anything - BARE metal) and get bolted in.... the 8ga power and ground should reach from the dist block to the amps just fine...
