System
Old Feb 6, 2007 | 01:37 PM
  #141
Scigon7's Avatar
so what do i do..run like 2 feet of 4 guage form the battery to a ground...and then groung the other 3ft in the trunk with the dist block and run the 8guage to the 2 amps? or does the ground wire from the battery need to be connnected to the amps?
Old Feb 6, 2007 | 01:44 PM
  #142
SCI_TC_GUY's Avatar
The battery already has a ground wire going to the chassis.... all you have to do is connect to a bare metal spot (on the chassis) so the ground signal can travel from your amp, through the chassis, and to the negative battery terminal - thus making the complete circuit...
Just connect the 4ga ground to a bare metal spot, connect the other end to a distribution block, and run the 2 8ga grounds to the negative terminal on the amps...
Old Feb 6, 2007 | 01:46 PM
  #143
Scigon7's Avatar
oh so i dont have to fround the battery...
where is a good grounding spot in the trunk? how hards is it to wire it all by urself? im paying to get a box made i dont really want to pay for wiring to
Old Feb 6, 2007 | 02:02 PM
  #144
SCI_TC_GUY's Avatar
If it's your first time, I'd probably get someone who has done it before to help - but it's not that bad....
I think I had my tC amps grounded to a bolt under the backseat - just hit the spot with a dremel to grind off some paint then attached the ring terminals to there...
Old Feb 6, 2007 | 02:38 PM
  #145
Scigon7's Avatar
couldi fit a nine2 and a nine2x under the floor in the trunk.. if i took out that styrafoam storage thing?
Old Feb 6, 2007 | 02:45 PM
  #146
SCI_TC_GUY's Avatar
That I'm not sure of.... it's possible, but you might end up having to take out both styrofoam trays to fit them...
Old Feb 6, 2007 | 02:57 PM
  #147
Scigon7's Avatar
i jsut need to be able to keep my spare tire...
yhwhdesign
Jun 11, 2021 03:34 PM
carid
Feb 10, 2019 10:46 PM
Hydryman
Feb 23, 2016 03:35 PM
brett561tc
Sep 15, 2015 06:33 AM
Subaru86
Jul 31, 2015 04:33 AM
