View Poll Results: Which sub should I take
Voters: 4. You may not vote on this poll
What Do you Think, Sound System. I NEED HELP ....
For The sub woofer Memphis 15-m3104D
For the Amp Kicker ZX550.3
For the front Alpine type-R or Polk Audio MOMO
For the enclosure OEM Bazooka
Rear speakers I'd keep them or NO?
Everything will be connected on 2 ohms
Please tell me what do you think ??? any recommendations?
Btw what do you think about Polk MOMO SUB's and infiniti Kappa ?I am thinking about MOMO and kappa because it's perfectly fits in OEM bazooka
I know it was million topics about that.....
Spec for the Sub
* High-density foam surround
Keeps the cone linear
* Kevlar reinforced paper cone
Strong and lightweight for high efficiency
* Custom-cast vented "M" Basket
Provides the platform for high excursion and cools the voice coil for better power handling
* Aluminum heatsink
Draws heat away from the pole piece
* Bolt-through modular motor
Easily removed for repair
* Single or dual 4-ohm voice coils
For the most versatile amplifier applications, 4 layers on 2.5" black aluminum former
* RMS/Peak (W) 300/600
* Sensitivity (dB) 91.3
* Magnet SIze (oz) 85
* Mounting Depth (in) 5.6
Spec for amp
# Amplifier Type 3 Channels
# RMS Power (4 ohms) 70 watts x 2 chan. + 210 watts x 1 chan.
# RMS Power (2 ohms) 85 watts x 2 chan. + 420 watts x 1 chan.
# RMS Power (1 ohm) Not Stable
# Bridged RMS Power Not Bridgeable
# Peak Power Output N/A
# Min. Impedance Unbridged 2 ohms
# Min. Impedance Bridged 4 ohms
# THD @ Rated RMS Power 1%
# Speaker Level Inputs Yes
# Amp Preamp Outputs Yes - 1 Pair
# Built-in Crossover Yes - LP/Full/HP
# High-Pass Crossover 50 - 200Hz
# Low-Pass Crossover 50 - 200Hz
# Subsonic Filter N/A
# Signal-to-Noise Ratio 95 dB
# Channel Separation N/A
# Bass Boost 0 - 18dB (subwoofer channel only)
# Bass/Gain Remote Yes (for subwoofer channel only)
# Fan Cooled N/A
# Fuse Rating 30A x 2
# Selectable High Pass, Low Pass, Full-Pass Crossover
# Input Sensitivity: Low Level: 125mv-5v, High Level: 250mv-10v
# 4 gauge power/ground leads
# Dimensions: 16 3/4"L x 9 5/8"W x 2 1/8"H
Spec for the Sub
* Aluminum heatsink
Spec for amp
# Fan Cooled N/A
