where should i run my battery feed to my amp....
i have a 2 or 4 gauge wire running to my amp i need to know where you guys usually put it through your fire wall and where you guys run all your amp wires from teh back of the deck please respond im in desperate help......a nice clean run to not no ghetto rig ____ thanks guys
I would normaly run the wire through a plastic groument. I normaly drill a hole and run the wire trough it using a plastic groument then i run the wires down the treshold pannel and under the rear seat or side pannel. What ever you do or how you run it do not run the power wire and the rca'a on the same side of the car YOU WILL HAVE PROBLEMS WITH ENGINE WHIN. If you have any more questions feel free to pm me any time. Hope this helps!!!!!!!
please read this before installing your system!
https://www.scionlife.com/forums/vie...ee+audio+setup
as for running the power wire. theres a rubber boot above the pedals. You should see it, run the wire through there. Do you have 2 or 4awg? You dont know what you have?
i ran my power for my amp through the hood latch thingy (follow your latch that opens the hood near your pedals, this will lead you to a grommet, slit a small hole in there and then feed the wire through there. it will lead to behind your driver side strut.). then from the incision, i ran my power on the driver side of the car, then behind the back seats and finally into the little cubby hole on the right side of the trunk. and thats my power run. lol
Originally Posted by rivas_203
or you could use the grommet behind the glove box near the ecu
I ran my power wire through the hole above the pedals, routing it through and above the pedals so there would be nothing to get snagged on. I ran the remoteturn on and power down the driver side, and the rcas down the left, through the plastic pannels, then under the back seat. and they come out through one of the holes into the spare tire cubby, i have my amp mounted in there, and cut holes in the styrafoam to put the wires through, and the speaker wires i just have under the little cardboard like thing that leans against the backseats when you recline them, theres a slit toward the middle. a good place to look is mando's interior stripping post, you can find it in the tech secition.
Link in sig.
Also:
Few more pics on drivers side:
https://www.scionlife.com/forums/vie...highlight=runs
And passenger side:
Also:
And passenger side:
missing_image
Feb 7, 2015 07:18 PM
carid
Dec 4, 2014 09:35 AM
kdanie
47
Feb 7, 2006 05:46 AM
. i plan to upgrade my wires also to even more isolate the interference.
