Cant shift down 3 2 L?? help please!!
Old Oct 26, 2010 | 03:02 PM
jimothy12's Avatar
I was messing with the hvac doing the led swap and it seemed to have messed up the trans or something?
i can physically shift to 3 2 or l but when im driving the trans doesnt do so for me...it has to be something electrical ? any ideas what i need to replace???
Old Oct 26, 2010 | 03:38 PM
highvoltage1's Avatar
are you serious? Where do you live? Im calling the local PD to revoke your license!
Old Oct 26, 2010 | 03:59 PM
BlckdOutTC's Avatar
dont shift like that in the first place. its an automatic...drive it like one and leave it in D
Old Oct 26, 2010 | 04:22 PM
RS2_1823's Avatar
^ Agreed.... auto driven like manuals normally tend to have problems in the long run.. Lower gears on an auto should only be use when the weather calls for it.
Old Oct 26, 2010 | 05:01 PM
TCpete's Avatar
your brain
Old Oct 26, 2010 | 05:14 PM
my06tc's Avatar
why would you want do shift down in a auto,what to look cool.......no reason for it unless bad weather calls for it...
Old Oct 26, 2010 | 05:17 PM
1GreeKtC's Avatar
Old Oct 26, 2010 | 05:24 PM
Ok ima lock this know. We had our fun. Hopefully he will read this and see why he shouldnt be doing this.
Old Oct 26, 2010 | 05:31 PM
jimothy12's Avatar
Default 3 2 L doesnt work ?? help
I dont shift down for whoever commented last time...i just would like my car to run properly....duh! What fuse or relay would affect this?
Old Oct 26, 2010 | 05:35 PM
Well first off you gave a horrible explanation. So like explain the problem in more than one crappy sentance! Are you trying to shift donw to 3-2-L while already driving in D or are you trying to start in L-2-3 and it wont do it that way? You gotta be more specific dude........Duh!!!
Oh and moving the lever into a gear is mechanical not electrical!
Old Oct 26, 2010 | 05:39 PM
jimothy12's Avatar
yeah so messing with my climate controll circuit board is going to effect the transmission?
It is electrical obviously! Since changing the leds voltage regulator and transistors blew some sort of fuses or relay. And i dont know which ones to replace.
Old Oct 26, 2010 | 06:10 PM
Spicy_McHaggiz's Avatar
Sounds like you need to learn how to work on your car. Shifting an automatic is a mixture between electrical and mechanical.
However, more information is needed about what exactly you replaced or messed with. Did you disconnect the battery? Where you anywhere near the shifter? Did you mess with grounds?
Seriously, stop acting childish if you want help.
Old Oct 26, 2010 | 06:35 PM
jimothy12's Avatar
all i did was reconnect the circuit board for the climate control and my windows, and blinkers dont work. Plus....if i try to go from drive to 3rd gear or 2nd or l...it doesnt recognize that im doing so and it doesnt shift properlly. I just want things to work again...and im not trying to shift a auto....i just dont know why it doesnt work properlly anymore and i want to know how to fix please!
Old Oct 26, 2010 | 06:42 PM
SquallLHeart's Avatar
you messed up. seek professional help...
i can't diagnose all your problems from behind a keyboard.
nor can i undo whatever it is that you did to cause your issues...
you did something... and you didn't do it correctly.... what it is?? who knows.
WRX1316_TcVicent
Jul 22, 2021 06:06 PM
Pkdust
Oct 20, 2015 04:27 PM
user9430961
Sep 24, 2015 01:09 PM
TheGovernmenT
Sep 4, 2015 11:57 AM
Wrencher
Jul 29, 2015 03:51 PM
