Low tire pressure warning light.
Ok, I've got the 18" Super 7's on my car which naturally don't work with the tire pressure monitoring system since there's NO anything where the rim mates to the hub to tell the car anything. The dealer awhile ago also confirmed this.
Anyways, over the past few days the low tire pressure warning light has been coming on.
I get out of the car KNOWING that the system does not work with the 18" and I check the tire pressure on all 4 tires with my pressure gauge and they're all right where they should be.
Now, it usually only happens on the freeway after crusing at highway speeds for about 30 minutes. It has never happened on my commute to work or a lot of around the town driving. Even driving it hard does not make it come on. It just pops on as I'm crusing along the freeway.
Anyone else seeing this?
I'm about 700 miles from my 10k service so I'm thinking I'll bring it up then. Either way the car is going to have it's 10k done before May 7th because I'm driving down to Palm Springs for a one week vacation and I want to make sure it's in tip top shape like it always is. I'm so looking forward to that drive but not if the stupid low tire pressure light keeps coming on for no reason.
I just had my 10k checkup . . the low pressure light didn't come on until I had the tires rotated. I took it to the dealer twice, they fixed it twice.
The light still comes on after a few mins of driving.
Is the 3rd time a charm? . . I will let you know.
If your tire pressures are ok, reset the system (with the car stopped and ignition ON, press the "RESET" button in the glovebox until the pressure warning light blinks three times and goes out.) If it comes back on, check the tires again, then take it to the dealer to have them check out the system. If tehy say the system doesn't work with the 18s, then argue with them and/or call Scion corporate.
Something just occoured to me though, if it measures it via revolutions how is it overcoming the laws of physics? When you're turning the weels on opposite sides of the car are turning at different rates. Or is the system smart enough to know the vehicle is turning and hence not trip the light. So there must be some sort of threshold I suppose.
As for there not being anything, on the rear wheels I can see a rubber plug in the rotor that for awhile I've assummed is where the system get's info from the wheel somehow and mine has a rubber stopper since I don't have the 17"s. But, perhaps it's a parking brake inspection hole since I believe the parking brake on the tC uses a drum type setup for it instead of messing with the rear calipers.
Oh well, something to check when I get home.
Also, I should have mentioned this but, this all started happening after I had to have a tire replaced because I got a nail in it and because of where it hit the tire had to be replaced. This was at about 9k miles and I'd find it difficult to believe that the neglible tread wear on the other three compared to the new tire is the culprit. I should see if I do have a nail in any of the other tires since nails like to travel in groups and perhaps I have a small enough of a leak to be tripping the system.
There's something you guys might be missing. There's a short reset and a master reset on the tire pressure system.
The short reset works in cases where that damn light comes on for no particular reason, or if you get a flat or something.
The hard reset isn't much more complicated, but its designed to reset the entire system, usually in the event of replacing wheels or tires, or both (as in this case). What you have to do is turn the car off, begin holding the reset light, and then turn the car on. The car will go through its normal start up sequence, and the Tire Pressure Warning Light will turn off. Meanwhile, you're still holding the button. After about 15 seconds, the light will flash three or four times. Once its done flashing, you can let go of the reset button. You have now performed a master reset. It is recommended that you do not do this on a short drive, and that the engine and computers be left on and the car be driven for at least 10 minutes in order for the computer to properly reset.
If this doesn't work, talk to the dealer.
I explained it in my post - "with the car stopped and ignition ON, press the "RESET" button in the glovebox until the pressure warning light blinks three times and goes out." You do that after checking all your tire pressures. It's not that complicated.
It sounds like the system was never reset properly (you might have just hit the button to make the light go out.) The other possibility is that your new tire is the wrong size, but that seems unlikely. If you reset it and it keeps happening, take it to a dealer.
So now it's engine running, hold down the reset until it blinks 3 times, which I imagine will take awhile since I do recall holding it down for a significant amount of time when it came on while on the freeway.
But, allow me another question, does the warning light need to be on to do this. I'm going to ___-U-ME no since this sort of reset would be required when changing rims, tires, etc. But, I'd like to make sure.
1) Unlock car
2) Get in car
3) Put key in ignition but don't turn it
4) open glove box
5) hold down the reset switch
6) Move key to the ON position
7) Warning lights will go through their normal stuff
8) Wait until tire warning light blinks 3 times
9) Start engine
10) Take a nice long drive
11) Serenety
So, do I have it right or do I still have my head up my butt. And I bow before those that pointed out my ignorance about how the system works. I found a good writeup on it at tirerack.com.
Link
I feel like I'm bashing my head against a wall. Car does not have to be running. It can be, but as long as the ignition is in the "ON" position, it will work. Car MUST be stopped. Then, after you turn the key, no need to do two things at once, just open the glovebox and hold the RESET button until the pressure light blinks 3 times.
If you still can't figure it out, read your owner's manual.
DaBlackBox
134
Apr 10, 2022 02:04 PM
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
kingofthecrate
Jan 21, 2015 09:28 PM
