Which brand of springs has the best results when low a TC?
Old Jan 12, 2007 | 04:50 PM
Shogun's Avatar
Originally Posted by L4rry_B1rd
TRD = 25mm = .9989839339"
If we count that as being accurate (AFTER settling), then the TRD makes the perfect 1" wheelgap with a 1" drop, which means that the Hotchkis is .7" lower in front and a full 1" lower in back and thus, handling would be EVEN worse.
However, the suspension FAQ says 1.25" and my car sure dropped more than an inch.
And here it is straight from TRDSparks:
TRD Lowering Springs lower the tC approximately 1.25”, front and rear
McGeorgeparts.com:
Lower the tC approximately 1.25”, front and rear
Now, Scion.com says they are 25mm, though, Sparks and McGeorge handle the springs all the time. And just LOOK at the pictures above. Compare to stock and it is easy to see that the car drops more than an inch. It it quite possible that the TRD are 1" when first put on and 1.25" when they settle. But in any instance, there is definitely more than a 1" drop. Enough people have before and after photos that I do not need to post mine.
Old Jan 12, 2007 | 07:15 PM
captainlaziness's Avatar
I think you're correct Shogun, mine are lower then 1".
xdejablu3x
Apr 19, 2017 03:44 PM
nightfox915
Apr 17, 2015 07:06 PM
ninoTc
Jan 26, 2015 05:22 AM
cid_mcdp
Jan 5, 2015 02:45 PM
fluxingnation
Dec 26, 2014 04:28 PM
