DIY: Brake Pads, Rotors, Caliper Painting, and Bleeding
Old 03-21-2007, 11:23 PM
  #41
11thhour's Avatar
great stuff,
thx dragon
sticky'd?
11thhour is offline
Old 03-30-2007, 07:27 PM
  #42
blipblop's Avatar
bump for another answering in regards of what size C-clamp is needed =)
blipblop is offline
Old 03-30-2007, 09:07 PM
  #43
Spect2K3's Avatar
Yes, I too would like to know. I used my friends last time, it was a medium size, but I forget the exact size...anyone?
Spect2K3 is offline
Old 04-02-2007, 01:27 AM
  #44
Spect2K3's Avatar
bump for the c-clamp. It is a medium sized c-clamp, but i'm not sure of the size
Spect2K3 is offline
Old 04-02-2007, 01:53 PM
  #45
dragonplayboy's Avatar
it was either 4" or 6", I think 4". I'm still hesitant to thumbs up you guys to do this work without knowing the stuff lo bux mentioned.
dragonplayboy is offline
Old 04-02-2007, 08:41 PM
  #46
davedavetC's Avatar
go get a brake pad tool it helps so much
davedavetC is offline
Old 04-02-2007, 09:09 PM
  #47
Spect2K3's Avatar
yea, I actually have one, but I am just trying to help people find out which c-clamp.
Anyway, I looked into what I used. it was the 4"
Spect2K3 is offline
Old 04-03-2007, 02:50 AM
  #48
davedavetC's Avatar
werd
btw get the dezod brake pads. they are incredible!!!
Old 04-12-2007, 04:09 PM
  #49
exige's Avatar
question.....about how much new brake fluid is needed when you flush everything out?
exige is offline
Old 04-13-2007, 02:13 AM
  #50
Spect2K3's Avatar
werd
Thanks, good to know. I recently through on some axxis XBG semi-metallic pads on the front, so thats out, but i've been looking for rear pads other than axxis deluxe. I'll have to look into the dezods, even though they are a bit more expensive
Spect2K3 is offline
Old 04-14-2007, 03:00 PM
  #51
Spect2K3's Avatar
What are the torque settings on these bolts for reapplication?
Spect2K3 is offline
Old 05-01-2007, 04:55 PM
  #52
blipblop's Avatar
i can't if my life depending on it get the top bolt of the front caliper off. there is absolutely no way that thing is moving. I managed to move one and I broke the bolt. Any tips as I got a set of new bolts but no can do. any ideas what I can do about it. This sucks.
blipblop is offline
Old 05-01-2007, 08:07 PM
  #53
Spect2K3's Avatar
The caliper bolt is the easy one. its the back bolts (17mm) that are the real pain in the butt. The 14mm are only torqued to 25 lbs. Are you sure you are and were turning it the correct way rather than tightening it??? I've heard of the bolt breaking when it was tightened to 50lbs.
To get the large 17mm bolts off of the rear to remove the rotors, I used my impact wrench for one and that came right off. I couldnt get it in there for the other bolt, so I used some extensions and combinations of other tools to eventually get it off
Spect2K3 is offline
Old 05-01-2007, 08:15 PM
  #54
blipblop's Avatar
I was CERTAIN that we were turning ot the correct way. I broke the first one as it snapped in half. And on the other side, the same thing, the stupid thing won't even budge. Horrible. This happened to my friends tC and my tC the same day as we were doing them together. The rear brakes were EASY... any idea on help? This sucks...
blipblop is offline
Old 05-01-2007, 08:55 PM
  #55
brian's Avatar
problem solved, we were being stupid...
brian is offline
Old 05-02-2007, 05:29 PM
  #56
riboflavin's Avatar
Nice DIY, I'm gonna use this when I swap my rotors.
riboflavin is offline
Old 07-10-2007, 08:44 PM
  #57
Fsu1dolfan's Avatar
x2 good info
Fsu1dolfan is offline
Old 07-14-2007, 02:18 AM
  #58
pollup's Avatar
not bad.
pollup is offline
Old 07-15-2007, 10:03 PM
  #59
kuo34's Avatar
Wow, one stop shopping for brakework. Another vote for a sticky on this thread.
kuo34 is offline
Old 01-02-2008, 02:46 AM
  #60
frame's Avatar
wow great write up.
frame is offline
Quick Reply: DIY: Brake Pads, Rotors, Caliper Painting, and Bleeding
