HELP needed ASAP. Broken Rear Upper Arm Bolt..
In desperate need of this. Part numbers 90119-12330(bolt) & 90178-12007(nut)
If you look closely at the schematic, right side on the upper arm, you see my bolt and nut.
Some other bolts on the schematic also share the same number that most of the bolts have, part number 90119 then 5 other digits.. They all start with 90119 BUT have 5 different digits after.
I'm thinking that is a specific bolt and wont fit on my upper arm if I get one of those. The specific bolt I'm looking for however, is not listed as you can see HERE:
http://www.toyotapartsoverstock.com/...rimLevel=18276
Do you guys think that the other bolts with number 90119 will be the same fit?
Skip to minute 1:10 to see the bolt. The left side of mine broke off with the nut still rusted onto the half of the bolt.
axtran
Apr 15, 2009 10:51 PM
Milizard
Apr 26, 2005 02:06 AM
