Hotchkis vs TRD Sways
Old Jan 13, 2007 | 11:35 PM
Spect2K3's Avatar
Default Hotchkis vs TRD Sways
2 things:
1st, does anybody know where I can get JUST the FRONT sway from hotchkis? (I think they are the only company to make one, correct me if i'm wrong)
2nd, I saw that the trd rear sway on the race setting (the stiffer setting) is 64% stiffer than stock. I then see that the hotchkis rear sway can be as stiff as 338% stiffer than stock. Are these numbers real? Hotchkis must be a crazy amount stiffer than the trd if it is....must be crazy oversteer (but I guess thats whey there is the front sway...)
Old Jan 13, 2007 | 11:37 PM
captainlaziness's Avatar
1st- Probably not, but you could troll the PPC section for one.
2nd- Yep real numbers, and (like you said) that is why the Hotchkis sways come as a pair.
Old Jan 13, 2007 | 11:45 PM
Spect2K3's Avatar
wow, that must be a crazy ride. I've had my trd sway on race since I bought the car, but that is a significant jump in stiffness. Must be crazy to drive
Old Jan 13, 2007 | 11:57 PM
--Final_Wrath--'s Avatar
Default Suspension
Where exactly would the rear sway go????? would it go on the floor??? Or am i way off on this one ....im new to this stuff..
Old Jan 14, 2007 | 01:03 AM
Spect2K3's Avatar
There is a stock rear sway already on the car. It is part of the suspension on the rear wheels, underneath the car. It connects the 2 rear wheels and makes it so that there can't be too much lean on one wheel, it tries to balance them out so that if you make a right turn for example, it will try to even out the amount of pressure on the left wheel when it wants to all go to the right. Ever see a SUV get some wheels off the ground when turning? this stiffens the ride to stabalize that....I dont know how to better explain it, I hope i'm making some sense.
Old Jan 14, 2007 | 01:46 AM
Default Suspension
So basically it goes under the car....yea, you explained it fine....thanks
Old Jan 14, 2007 | 03:14 AM
trdtcpr's Avatar
I went from the TRD sway to the Hotchkis set and certainly there is a difference. As for getting just the front call Hotchkis directly and see if they would sell just the front, the least you can get is a no.
Old Jan 14, 2007 | 03:38 AM
Spect2K3's Avatar
I can only imagine, it MUST be stiffer...just look at the numbers! wow!
I'll give em a call, after all, my car has a tendency to oversteer with my trd sway on race. I'm just afraid that the hotchkis front sway, being meant to counteract the stiff hotchkis rear sway, may cause my car to understeer since I only have the trd bar. any thought?
Old Jan 14, 2007 | 03:43 AM
A Hotchkis front bar up front and a TRD bar out back is going to throw handling balance out the window.
Old Jan 14, 2007 | 03:45 AM
Spect2K3's Avatar
yea, that sucks, makes sense though. So I gotta either leave it as is or get both hotchkis sways. bummer!
Old Jan 19, 2007 | 01:33 AM
m6ar2cel6oTC's Avatar
i just bought the front performance tech i think its called from nopionline because i already have the trd rear sway. will that throw off my handling? and if so why? the back i think it's 22mm and the front is 24 mm.
Old Jan 19, 2007 | 01:29 PM
trdtcpr's Avatar
I sold my TRD rear sway and bought the Hotchkis set for that same reason since Hotchkis R&D for making the set to handle accordingly front with the rear I prefered having their set better than a mix & match. just mho.
Old Jan 19, 2007 | 10:59 PM
Tcguy85's Avatar
the trd rear is enough if your just driving on the street, if your autocrossing more might be a good thing though.
Old Jan 19, 2007 | 11:09 PM
trdtcpr's Avatar
true!
maximthegreat
Jan 19, 2016 02:31 PM
mxwes
Aug 30, 2015 09:11 PM
Scionxa180
Aug 30, 2015 04:12 PM
AMS13
Aug 20, 2015 07:26 PM
