New Owner of 2007 Scion tC TRD (Son’s)..Brakes are soft..
Old Dec 21, 2020 | 02:49 PM
Capnyak's Avatar
Default New Owner of 2007 Scion tC TRD (Son’s)..Brakes are soft..
We brought home this little coupe, and its really fun to drive. We unfortunately have a problem.
Need help with this: brakes are soft, ling pressing to the floor. Brakes are good, had master cylinder replaced. Now what?
I am a veteran of the US Army, saw that other post, and my Son Xander is the overzealous teen in the coupe. It is tuned with Injen CAI and probably has other things I will learn about!
Jack
Sticky How To Advanced Search SL (Scion Life)
______________________________
Last edited by MR_LUV; Dec 21, 2020 at 04:46 PM. Reason: Moved to Correct Forum by Administrator
Old Dec 21, 2020 | 02:56 PM
drizzoh's Avatar
If the brakes are soft thats usually a sign air is in the lines. Try bleeding them and/or flushing the brake fluid if its older than 3 years. There are lots of good DIY's out there for how to do this and most dont involve more than a few tools, a length of hose, fresh fluid and about 30-45 min of yours and your sons time.
Old Dec 21, 2020 | 03:44 PM
MR_LUV's Avatar
Administrator
Administrator
Hello Capnyak! Welcome to SL!
Looking forward to see you in:
Please Check out the informative Stickys above in the Header of this Forum HERE.
MR_LUV
Administrator
__________________
Old Dec 21, 2020 | 09:14 PM
Capnyak's Avatar
Default Brakes are to the floor
we had everything checked,bled, and the master Cylinder replaced, not in that order either. I expected it to be tighter.
Old Dec 21, 2020 | 10:31 PM
62Fender's Avatar
Ceramic pads or semi-metallic?
Ceramic pads feel a little softer than semi-metallic but they're fine for non-spirited drivers. If your son is a spirited driver, he might like semi metallic pads better than ceramic. Semi metallic pads are rougher on rotors but might give more peace of mind. I don't know whether semi-metallic will improve your stopping distance.
Old Dec 29, 2020 | 02:08 AM
Capnyak's Avatar
Default Brake pads.
I forgot to ask.
i am afraid this is going to be a rabbit hole x10
thinking new Lines, to rule out any oddball pressure issues?
thanks for the advice all!
JM
Old Dec 30, 2020 | 05:37 PM
alxm's Avatar
Moderator
Moderator
The brake calipers may be worn out and leaking. Might be time for replacements.
sciontc_mich
Dec 1, 2017 09:21 PM
JL514
20
Jul 11, 2014 11:03 PM
sciontc_mich
Sep 18, 2009 06:51 PM
speshuled619
Aug 25, 2009 03:21 AM
ShinyNewPennyXb
11
Jan 24, 2009 06:00 PM
