noise problem
Old Sep 22, 2009 | 10:35 PM
dcs2k79's Avatar
Default noise problem
I have a noise problem and i was wondering if anyone else had it
The noise is a roaring noise that changes with speed and slight vibration. it doesn't happens when the car is stopped.
I just got 4 new tires and the alignment helped a little, suspension is good they checked that. the car has 80K
this noise is driving me nuts
Old Sep 24, 2009 | 02:21 PM
happyhick025's Avatar
where is it coming from like inside the car or out?
Old Sep 24, 2009 | 06:44 PM
stussy1's Avatar
what type of tires did you get? The tread of the tires has to do with the noise youre hearing. A more aggressive treaded tire along with a thinner sidewall will transmit more roadnoise into your cabin then stock tires.
only real thing you can do is dynamat the floor, especially around the wheel area to quiet anything down. Or you can go the route of changing tires again to something with a little bit thicker sidewall and less aggressive tread pattern. But since you just bought tires i doubt you want to go that route.
Green
Mar 19, 2015 01:47 PM
RayScionXB
Regional - Pacific South
19
Mar 5, 2015 08:22 PM
RayScionXB
Regional - Everywhere Else
Mar 3, 2015 08:27 PM
evolving_machine
Feb 27, 2015 09:53 PM
gularti
Dec 4, 2014 01:21 PM
