Odd sounds
Old Jun 25, 2005 | 08:40 PM
JCLiP's Avatar
Default Odd sounds
After i put the TRD drop kit (Spring/shocks/anti-sway bar) on, as im driving i hear a "wshhh" sound coming from what i think is the rims. Is it from the brakes? what do you think?
Old Jun 26, 2005 | 07:22 AM
reagulator's Avatar
can you elaborate on the "wshhh"
Old Jun 26, 2005 | 05:05 PM
JCLiP's Avatar
The "wshh" is more attempt to duplicate the sound that i hear coming from the rims ever time the wheels rotate. THe sound came about after the TRD equipment was installed. It sounds like it might be from the disc brakes, possibly to tight?
Old Jun 26, 2005 | 05:32 PM
Casus_Belli's Avatar
Sounds like break pad rub?
#1: Back-up and stop a bunch of times to adjust them.
#2: Still whisshing. Jack up each corner and test to see that wheel spins freely. While you're at it. Check to see if anything is rubbing against wheel or tire.
#3: Drive it around the block a few times without breaking much. Check wheel hubs and rotors for excessive heat. Careful on the rotors, they may burn your finger. It's unlikely that someone could screw-up re-assembly of all four wheels. All should be about the same temp - front maybe a little warmer than rear.
#4: If nothing is rubbing or exceptionally warm, then turn up the radio.
Old Jun 26, 2005 | 07:17 PM
JCLiP's Avatar
Right on!!! I apply the advice. Peace be with you!
laforze
Feb 17, 2016 02:40 PM
kmouse64
Sep 4, 2015 01:11 PM
Threequalseven
Aug 26, 2015 04:24 PM
capgrover
Jul 25, 2015 05:00 PM
kmouse64
Scion xB 2nd-Gen Wheel & Tire
Jul 22, 2015 10:13 PM
