Parking Brake/ Hand Brake
Old Jan 11, 2011 | 08:36 PM
ahatch133's Avatar
Default Parking Brake/ Hand Brake
Living in michigan parking on hills and ripping my hand brake up and down (probably should not use it so much) and using it in the snow for a unexpected slide or a occasional snow drift um my hand brake has pretty much gone
ive searched around and looked all of SL and i cant find anything how much it would cost to replace or repair?
thanks guys
drive safe its like a blizzard out by me
Old Jan 11, 2011 | 09:26 PM
RoboCop's Avatar
You can tighten it yourself. Search
Old Jan 11, 2011 | 09:48 PM
SquallLHeart's Avatar
did you wear out the cable... or did you completely abuse the hell out of the brake and the pads need replacing?
Old Jan 11, 2011 | 09:58 PM
helloninja's Avatar
There are 2 points to adjust. Under the handle and at the rotor. Start at the rotors. It really isnt worth taking to a shop. You will pay lots of labor fees. This can be done in your garage or drive.
1. Release parking brake
2. Remove wheel
3. Remove black rubber plug on rotor.
4. With hole at bottom, locate teeth inside hole and rotate up until rotor doesnt spin freely
5. Roll down 3-5 teeth.
6. Repeat with other side (same number of teeth be sure to count correctly).
7. Follow this DIY to adjust handle
https://www.scionlife.com/forums/sho...hlight=e-brake
Old Jan 13, 2011 | 03:24 AM
Coolwaterz's Avatar
safer if u tighten from the rear brakes first. got my free old change from toyota last year and they tighten it for me.
JoeyBishop
Sep 28, 2022 01:34 AM
Dmmcclair
Aug 13, 2015 07:14 PM
fxeditor
Jul 1, 2015 06:18 AM
fxeditor
Jun 15, 2015 08:56 PM
AdPock
Apr 8, 2015 10:01 PM
