Rack and Pinion leaking from lines..
Old Jan 10, 2019 | 01:00 PM
xdejablu3x's Avatar
Default Rack and Pinion leaking from lines..
Has anyone had issues with fluid leaking from their headlines in the Rack and Pinion? My boots are not leaking but I noticed fluid is leaking where the hard lines meet valve body on the Rack and Pinion.
I don't want to replace the whole thing because it's pretty much half the cost of what our cars are worth right now.
I'll post some pictures up later today. I had a previous leak from torn CV boots and road grime down there but I really won't be able to work on the car until next weekend when I plan on raising it as well.
_________
Old Jan 16, 2019 | 01:25 AM
xdejablu3x's Avatar
Some reason I can't upload and add photos to my albums on SL but here is a photo of our rack and pinion. Pretty much there is fluid leaking around the left side where what appears to be red seals? That's where the lines connect to and it seems to be leaking in that general area.
Old Feb 15, 2019 | 02:24 PM
xdejablu3x's Avatar
Here's where they are leaking. At the lines right above the inner tie rod that connect to the rqck and pinion. I also relized that whatever shop put did my power steering fluid probably put the wrong fluid in there because Dexron III (ATF) which is used in our our vehicles and tons of other Toyotas is red and not yellow like other power steering fluid. Has anyone came across this issue before? I sure as hell know someone has as this car has been around for over a decade and isn't the only Toyota that uses Dexron III as power steering fluid.
Old Feb 15, 2019 | 09:15 PM
62Fender's Avatar
Honda PSF is yellow. Is that the cause of the leak? Hard to say. The Scion manual says Dex II and III temp range is 167 to 176 degrees f. The tC power steering return line has no cooler and Dex fluid scorches. I don't know the temp range of Honda PSF but the tC environment probably isn't very kind. I have to change Dex III every 25k miles or I can't read the fluid level on the reservoir. I recently used Dex VI. It's synthetic and supposed to resist scorching.
From the pic I can't tell where it's leaking. Might want to check the line fittings. The tC manual specifies 18 ft lbs.
Old Feb 17, 2019 | 04:10 AM
xdejablu3x's Avatar
Thanks for the response. I read about how our cars and some other Toyotas beat up DEX III a lot on power steering. I tried reaching back in there with my wheel off and it's a tight fit. The upper fitting is 17mm or 18mm (I forgot). Not much room to play. Is DEX VI back spec'd to be used on our cars?
Old Feb 17, 2019 | 02:06 PM
62Fender's Avatar
Good question. I never verified Toyota's approval however Dexron VI mfgs say Dexron VI exceeds Dexron II and III specifications.
renegade4x4
Nov 14, 2011 07:54 AM
kayi078
16
Sep 22, 2010 09:47 PM
pist
23
Jun 2, 2009 02:37 AM
CajunTC-RLS-1-2367
Aug 6, 2008 03:37 AM
douglasinct
Jun 21, 2008 05:52 PM
