View Poll Results: Enigine Dampner To go with
Stiffy
79.17%
Secret weapon
16.67%
Other
4.17%
Voters: 24. You may not vote on this poll
Scion tC Engine dampners???
Old Feb 23, 2006 | 01:23 AM
zer0's Avatar
My stiffy is incredibly loud, dynamat and all. I can hear everything as the RPMs increase. Am I the only one.
Ingalls+Injen=Loud
Old Feb 23, 2006 | 04:27 AM
Scion-ce's Avatar
Originally Posted by Scott8
How much harder is the Motor mounts compared to the Stiffy install?
It can be tough sometimes to put a stiffy in where its supposed to go (between the walls)
Old Feb 23, 2006 | 04:56 AM
FLINT's Avatar
Ingalls+Injen=Loud
the ingalls etd tends to be loud at first starting up the car in cold weather. when mine warms up, i dont hear much and i have mine on the 10mm race setting. i love mine
Old Feb 23, 2006 | 05:12 AM
yellot00tr's Avatar
i have to install my weapon r, i'm just having some issues with figuring out how to get it to fit because of the ac line that they moved to install the supercharger. has anyone been able to get the weapon r to fit on a sc'd tc?
Old Feb 23, 2006 | 05:32 PM
FLINT's Avatar
weapon r should have r&d that b4 they tried to sell them. it sounds like they use us for their r&d and then change things later, but good luck with that.
Old Feb 23, 2006 | 05:35 PM
ScionBandit's Avatar
sIcKsCiOnS
DelMarVa
Scion Tuners
i had same issue with mine, i have no s/c. the AC line was in the way
i bent it slightly to help the issue, bent it back after the damper broke on me and i took it out
Old Feb 23, 2006 | 08:22 PM
DynomyteSW's Avatar
i only had to move the ac line bracket slightly and zip tie the power steering hose up and out of the way... a trip from ft lauderdale to orlando in back and no issues w/ rubbing or anything just a little noisy on the freeway
but it's not that bad
Old Feb 24, 2006 | 01:23 AM
yellot00tr's Avatar
that's annoying. none of these engine dampers are perfect fit without messing with the ac line in a sc'd tc. i've heard that people were having issues getting the ingalls fitted in properly as well. dynomyte-any pics of ur damper?
Old Feb 24, 2006 | 10:16 PM
PghtC's Avatar
Are the ZPI motor mounts available yet? Does anyone have them, or a picture of them?
Old Feb 25, 2006 | 03:52 PM
Scott8's Avatar
Please show pics of the mounts or a DIY!!!
Old Feb 25, 2006 | 05:30 PM
sIcKsCiOnS
DelMarVa
Scion Tuners
the mounts are not out yet, they had to send them back to the company for proper fitment. will be about another 2weeks or so
i will post pics once i get mine in
Old Feb 28, 2006 | 09:21 PM
robstamina's Avatar
I have the damper and Energy motor mounts on the civic si and swear by the combo...
The Stiffy takes care of front to back engine movmnt and the motor mounts take care of side to side...
The damper is adjustable in relation to dampening as opposed to the mounts which are usually really stiff and take about 500 miles to "break in"...
I HIGHLY recommend the combonation of stiffy and mounts...if you are concerned about vibrations and maintaining a "factory" ride I recommend neither..
Mounts are a PAIN to put in and end up costing more to install if you have a shop do it ..
the damper is comparative to putting in an air intake installation wise..so they both end up costing about the same overall..
In terms of vibrations no matter what you do when you stiffen up the engine you are getting some residual vibrations...
daniinpitt
Apr 4, 2015 08:07 PM
Halo19boy
Jan 27, 2015 10:19 PM
Ramroids55
Jan 16, 2015 02:42 PM
greytc
Jan 12, 2015 09:49 PM
AdmirN
Jan 5, 2015 10:19 PM
