Shocks and springs
Old Aug 16, 2005 | 09:26 PM
tChui's Avatar
Default Shocks and springs
Is it necessary to change out the shocks if your gonna change the springs?
Old Aug 16, 2005 | 09:30 PM
GoSwim's Avatar
It's not necessary, but it is highly recomended. The factory shocks are not meant to handle lowering springs and will blow prematurely.
Old Aug 16, 2005 | 09:51 PM
rivrtc's Avatar
It is my understanding that if you use the TRD springs with the 1" drop that your stock shocks should hold up fine.
Old Aug 16, 2005 | 10:10 PM
tChui's Avatar
Because i wanted to get h-tech's but the koni's are so expensive
Old Aug 18, 2005 | 02:46 PM
NuNuNYC's Avatar
For the majority of ScionLife members, I was wondering why for all the people who get aftermarket springs, don't upgrade their struts.. Most would say it's a given that you should upgrade your struts if you were to get the H&R, Tein H-Tech/S-Tech or Tanabe DF210 (or lower) springs... And yes, many will also say that it's not necessary but recommended...
And for those who have bought aftermarket struts with their springs, why not go for the Tein Basic Coilovers which can be had for $715 by a fellow SL member?? I'm just a bit confused how a spring/strut setup can be so much more than a coilover setup, especially the labor if the struts are inserts and require cutting in the stock strut housing?
Old Aug 18, 2005 | 03:08 PM
GoSwim's Avatar
I agree with you. I say it's recommended because as soon as I post that you need to replace the shocks/struts someone pops up saying that you don't have to. Technically they're right, but that's until your shock/struts give out. I also agree with your point that coilovers are better and more cost effective, but some people buy their springs and then later replace their shocks/struts. It gives them time to have something and then save up for the other.
goatbelly
Jul 12, 2015 10:13 AM
carid
Feb 12, 2015 11:54 AM
fluxingnation
Dec 26, 2014 04:28 PM
swtbabiboi4u
Oct 13, 2003 04:38 PM
swtbabiboi4u
Oct 10, 2003 01:40 AM
