Springs settling.. does your weight affect the speed ?
Old Mar 9, 2007 | 09:57 PM
tcva's Avatar
Default Springs settling.. does your weight affect the speed ?
I got my hotchkis installed 2 weeks ago and just recently i decided to measure my gaps and my fronts are fine but my passenger rear is 1/2 inch bigger than the drivers rear.
Havent had anyone sit in my car since the install and i do weigh 210lbs so i'm not sure if it needs more time.
THe guy who installed mine has done 10+ scions so i doubt it's a mechanical error.
Old Mar 9, 2007 | 10:05 PM
Duartizzle's Avatar
im sure is ine...
Old Mar 9, 2007 | 10:06 PM
hellsyphon's Avatar
This usually happens to aftermarket springs when they are settling because of the uneven weight distribution when you are in the car. Either put some weight in the trunk on the right side or carry some friends around and that gap will equalize in no time.
Old Mar 9, 2007 | 10:07 PM
tcva's Avatar
so it's not a defect with the springs ?
Old Mar 9, 2007 | 10:12 PM
mitchelltc1's Avatar
curious too...I can't imagine 200lbs doing anything
Old Mar 9, 2007 | 10:17 PM
Scott8's Avatar
the front weight will make the front drivers side settle the fastest. My front did that as well. I weigh 215-220 and it took longer for the rest of the springs to settle in. I have had them on for a while now and they all have the same look. You should be fine.
Old Mar 12, 2007 | 01:55 PM
thanks, I was hoping it wouldn't be a permanent result. Maybe I will throw some weight on the right side then...
Old Mar 13, 2007 | 08:07 PM
tcva's Avatar
do you remember how long it took for the passenger side to match your drivers side height ?
Old Mar 13, 2007 | 08:28 PM
Daskid's Avatar
When I first installed mine, this was the issue I was worried about. I weigh around 145- 150 lbs. and using it everyday will eventually affect weight distributiion. I put a dumb bell set that weighs around 50 lbs underneath the passenger seat and moved my sub to the rear passenger's side. I think it took about 1 1/2 months for it to even out. They have 1/16" and 3/16" differences for the front and the back respectively.
Old Mar 13, 2007 | 08:39 PM
tcva's Avatar
i put these stone marbles(50lbs~) in the trunk on the passenger side and i still see 1/2inch difference.
The thing is.. even if it evens out with the added weight.. it's going to be different when you take out the weights.
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
debris
Mar 13, 2015 08:15 AM
NonStopTuning
Jan 20, 2015 05:20 AM
fluxingnation
Dec 26, 2014 04:28 PM
hydrogen
Oct 29, 2003 04:58 AM
