Tough to Shift when its cold
I have a twm short throw shifter and when it has been under like 35 degrees engaging first gear is very tough until the car is completly warmed up. I find my self having to put the car into 2nd gear and then into first from there sometimes to get 1st engaged? Is this normal and if not is the dealer going to give me a hard time because of the short shifter? Thanks
I own an s2000 as well and it is no where near as hard to shift into gear when it is cold as this car is, and considering the S2000 is a high performance car it shoul be the other way around. I have driven many a five speed cars in the winter cold and this is the first such car that requires two or three tries before first gear cann be selected, its very annoying and disconcerting.
Scion Corps
DeepSouth Scions
i have not had any problems in the cold, then again i usually let my car warm up for about 5 mins when its really cold. however even when i dont i still dont have that problem
Originally Posted by tictacktc
What do you mean by "shifts rough"? Is it a little hard to get into certain gears?
tranny fluid is really thick. needs time to warm that up.
clutch and other metal parts are still very cold and havent warmed up yet.
and you have a short throw shifter... adds less leverage making it feel heavier/harder to shift
and side note:
the tranny for the TC isnt that great of a tranny so give it some slack.
yes its normal
and side note:
yes its normal
Actually, a short-throw would give you less leverage, which would make it harder to shift. (Longer lever = more leverage.) We know what you meant, though.
I've never ever ever had a problem getting it into first (stock shifter), but then again where I live it almost never ever ever gets below freezing. Maybe it has to do with the shifter (too short, too tight, li'l screw fell down into the works and got lodged into the wrong place...???)
Just bought a manual tc a couple weeks ago, and was having the same problem. When I asked the dealership this was their reply: "if you cruise in 1st gear too long there is a lever in the trans that makes 2nd gear difficult. (in trans-am’s it locks )" They didn't mention anything about the cold, but when mine warms up, it shifts a lot smoother.
hahaha are they trying to tell you the tc has skip shift??
either way better fluid should fix the issue
NonStopTuning
Jun 29, 2015 07:42 PM
carid
Mar 30, 2015 07:08 AM
minter66
Dec 15, 2014 01:45 PM
Dylan
Mar 3, 2004 08:03 PM
