New Wheel Fitment Thread
Old Sep 8, 2009 | 08:05 PM
  #201
Ro_Ja's Avatar
Good point.
Old Sep 12, 2009 | 04:39 AM
  #202
thegreathoudini's Avatar
alright, i haven't seen this yet and based on the chart i think i should be ok, just want to double check
I'm looking at
17x7.5 with an offset of 45 on the TRD kit (RS 1.0)
and the chart says 225 tires. I'm assuming if i go with that setup i'll be all set?
Old Sep 12, 2009 | 04:56 AM
  #203
Ro_Ja's Avatar
You'll be fine.
Old Sep 12, 2009 | 04:59 AM
  #204
thanks, I thought so but if i'm going to spend the money i don't want to screw it up
Old Sep 19, 2009 | 02:17 PM
  #205
SilentThreat's Avatar
Default Help!
Alright guys, this is like, my first post ever on Scionlife, so i figured i'd ask the experts.
I was looking into some Rota grids, and decided to say "____ that" to buying knockoffs and trying to stick to a low budget.
I went with the Work Emotion XC-8 wheels in 18"
http://www.workwheelsusa.com/product...ry=27&wheel=77
HERE is my question/concerns:
I worked a deal to get a set of front and rear 18x8.5 5x100 with a 34mm offset. I AM VERY WORRIED ABOUT RUBBING!
suspension is Tein H-techs.
Will this work without rubbing?
What kind of look will this be? Tuck? Flush?
What tire size should I get and will i need to stretch them?
Will I need some kind of negative camber kit or fender rolling to make these work?
Thanks in advance to anyone who can accurately answer these questions. So few people go with legit rims, and when I'm blowing over 3k on a setup I wanna make sure it fits right, and looks good with no problems, ya know?
Old Sep 19, 2009 | 08:43 PM
  #206
Ro_Ja's Avatar
to you for not getting Rotas.
The 18x8.5 +34 is not available in our bolt pattern, so are you ordering a custom set? Regardless, that combination of width and offset will be flush. It won't be poking past the fender, but it should be in line, or very close to it. You might rub on a full car load or when making hard turns. You can get either 255's and have a beefier tire that isn't stretched or stretch a 225 on it to reduce the chance of rubbing. If it does rub, it's an easy fix. Just roll the fenders and add a little bit of camber.
Old Sep 19, 2009 | 11:01 PM
  #207
Thank you! and yes this is a custom order straight from Work Wheels.
Just to clarify: the front AND rear in this combination and offset will be flush?
Additionally, i dont want to stretch tire sizes, so specifically what tire size options are available to me? I dont know a lot about tires, so im talking like, 255/40? 245/45? i dont know exactly what the numbers means when it comes to tires so i'll need a little more specific of an answer please!
and thanks, tons of people are "saving" for rotas. Really? knockoff of a racing brand? Isn't the whole point behind those brands the lightweight and strong characteristics? Might as well spend a little more and get something that has a little respect behind the name IMO
Old Oct 25, 2009 | 12:35 AM
  #208
PeterPanda's Avatar
alright, i'll be running pretty much the same set-up as ^ (h techs ... 18x8.5 but +37 instead of +34)
you said he should be alright so that means i'd be in the clear as well
my question though is suggested tire dimensions that would pretty put me at ease as far as no rubbing goes. (i'd rather not cut, roll, pull anything) would 225/35 work for what im trying to do, or not do for that matter
Old Dec 13, 2009 | 11:13 PM
  #209
atl20ae's Avatar
225/40/18 on 18x8 et42 at stock height... that won't rub on the front inner lining correct? (girlfriend's car and any little noise will freak her out)
edit: just found a good deal on 235/40/18 so same question for both sizes.
Old Dec 14, 2009 | 12:33 AM
  #210
rrimportracer's Avatar
235 will possibly rub the liner, but 225 wont for sure... i had that on one tc with an 18x7.5. 18x8 will stretch the tire out a little and youll be fine with 225 for sure... 235 maybe, maybe not, not sure
Old Dec 14, 2009 | 12:39 AM
  #211
Ace83's Avatar
Ronin Scion
225 will still rub with the liner depends on how low your car and your alignment settings.. less likely though.. i was on 18x8 225/40/18 and it still rubs sometimes, on a really stiff tein coilovers. Now im on 235s and its rubs more, just learn some new driving habits and you can live with it daily lol even on 255s
Old Dec 16, 2009 | 06:19 PM
  #212
atl20ae's Avatar
Thanks for the responses. I put 225/40/18's on today and no rubbing
Old Dec 20, 2009 | 02:35 PM
  #213
JINeration's Avatar
i have a question
i am about buy some rims that are 18X8 and 18X9 and im lowered on megan coils and right now my wheels are tucked in the rear so i am wondering what kind of tires i should get for these rims
Old Dec 24, 2009 | 07:32 PM
  #214
JEMtC's Avatar
hey guys i got a quick question about a set of rims and tires:
17x8 et.20 (front) with 205/40/17
17x9 et.20 (rear) with 215/40/17
will the offset on the rims poke a lot from my fenders or will it be a little bit that i could just camber the wheels in a bit? and i know ima have to roll my fenders, which is fine, but i dont want to pull them!!!
Old Dec 24, 2009 | 08:12 PM
  #215
Ro_Ja's Avatar
You should be fine, just add camber as necessary.
Old Jan 24, 2010 | 04:23 PM
  #216
lukeyd900's Avatar
I am on Tein H-Techs and I was looking at upgrading from 17 x 7.5 w/ 45 offset with 225/45 tires to 18 x 7.5 w/ 45 offset with 235/40 tires. Will I have any issues?
Old Jan 24, 2010 | 07:53 PM
  #217
Ro_Ja's Avatar
No
Old Feb 9, 2010 | 01:28 PM
  #218
night87's Avatar
having some confusions about the offsets b/c i'm new to the wheels section but how does a 17x7.5 offset +48 fit on the tC
Old Feb 9, 2010 | 02:18 PM
  #219
Ro_Ja's Avatar
you'll be fine...it's basically close to stock looking
Old Feb 9, 2010 | 02:55 PM
  #220
americandesi's Avatar
Will 17x7 40et with 225/45/17 rub, when lowered with s techs?
