Scion tC 2G Aero & Exterior Aero parts and exterior dress items...
Removing Vinyl Tape off A-Pillars (Help)
Old Jul 17, 2012 | 04:44 PM
Cesar's Avatar
Default Removing Vinyl Tape off A-Pillars (Help)
So yesterday I attemted to remove the black tape off the a-pillars and I succeeded however, there is still pieces of it close to the windshield that I have no idea how to get off with out a razor blade... does anyone have an easier way of completing this task of mine? haha
I'll post up pics tonight when I get home... I think it looks pretty dope...
Old Jul 17, 2012 | 05:52 PM
talt2008's Avatar
when i did mine i used a razor to cut the vinyl along the windshield. (the inside of the pillar between the windshield gasket and the a pillar) i hope this helps. best of luck to you
Old Jul 17, 2012 | 05:54 PM
SuBSiN's Avatar
You can always use a rubber blade
Sent from my HTC EVO 3D X515m using Tapatalk 2
Old Jul 17, 2012 | 07:14 PM
Cesar's Avatar
I have to find na blade tonight! I'll post up sum pic as well for you guys!
Old Jul 19, 2012 | 01:33 AM
AHope888's Avatar
I used a toothpick and tweezers to get all of the little stubborn pieces under the weatherstripping, worked great.
Old Jul 22, 2012 | 02:05 AM
NeonBodyStyle's Avatar
When I removed mine, I had a bunch of swirls in the paint, I'm not sure if there's still some adhesive left or the adhesive remover itself damaged the paint. Any ideas?
Old Jul 22, 2012 | 02:14 AM
TeeCizzle's Avatar
I would of used a Heat Gun...Will make it very easy to remove.
Old Jul 22, 2012 | 04:56 PM
topher86's Avatar
There is tons of stuff in the wax section that will take out swirls and orange peal just take a look. my dad has a black vette so he has used just about all of them and it just seems to rely on how much work your willing to put into it.
Old Aug 12, 2012 | 09:35 PM
Errikos's Avatar
use a clothing steamer, it heats up the vinyl and also kinda lubes it up break the vinyl down the middle this will allow you to pull it from the middle out and you remove all spots even under molding did this on mine it took a little effort but no cutting was required
brett561tc
Sep 15, 2015 06:33 AM
bmxScion
Jul 23, 2015 12:07 AM
sciongirl13
Scion xA Aero & Exterior
Jul 22, 2015 02:28 AM
carid
Jul 14, 2015 01:10 PM
excessads
Jul 13, 2015 11:41 AM
