2013 Scion tC Wont Start after wreck..
Old May 17, 2019 | 07:30 PM
Smokeuu's Avatar
Default 2013 Scion tC Wont Start after wreck..
I bought a Scion wrecked in the front. After getting it home turn the key and dash comes on. No power anywhere else.
No door locks, windows won't work, no radio. Car don't click when turned to start. Only power is the dash light.
Any help would be appreciated.
______________________________
Last edited by MR_LUV; May 17, 2019 at 10:21 PM. Reason: Moved to Correct Forum by Administrator
Old May 17, 2019 | 07:51 PM
62Fender's Avatar
Originally Posted by Smokeuu
Car dont click when turned to start.
Pop the hood and eyeball the starter. Check for loose connection(s) and or broken actuator. Test the battery to make sure it's charged.
Old May 17, 2019 | 07:55 PM
Smokeuu's Avatar
All are good!! That wouldnt make the car have no power anywhere else anyways
Old May 17, 2019 | 08:02 PM
62Fender's Avatar
Have you removed the damaged parts? Not sure you'll find anything that prevents starting but may be worth a shot.
Might try a DTC scan (assuming the socket is getting power with the key is in the on position.)
Old May 17, 2019 | 08:37 PM
Smokeuu's Avatar
I have removed all bad parts. Nothing broken or cut. Everything looks good. Wasnt that bad of a wreck. Tried to scan it but the obd has no power either
Old May 18, 2019 | 03:26 PM
62Fender's Avatar
Sounds like you'll need to meter each component from the battery to the ECU. Might also inspect the front end ground point(s) to make sure they're intact.
Domasticus
Scion tC 2G ICE & Interior
Sep 12, 2019 08:23 PM
kmrort
Dec 19, 2012 12:08 AM
Evil
Aug 14, 2011 08:56 PM
x219c
Scion tC 1G ICE & Interior
Aug 1, 2009 08:59 AM
idriveatC
Jan 17, 2009 09:25 AM
