Does it matter which Battery cable you take off?
Old Nov 20, 2019 | 09:46 PM
Cutlass89's Avatar
Default Does it matter which Battery cable you take off?
To try to clear a c.e.l. does it matter which battery cable you take off. I think i just left gas cap loose.
Old Nov 20, 2019 | 11:14 PM
MR_LUV's Avatar
Administrator
Administrator
Normally, you Always Remove the (-) NEG Battery cable first, no matter what your problem is:
How to Disconnect a Car Battery
Yes, it is possible you can cause a CEL code with a loose gas cap.
Years ago, I had a older Chrysler van. I lost my original gas cap and replace it with a auto store bought cap.
It cause a CEL code and Smog Check Failure. I replaced it with a OEM gas cap and Problem Solved.
Old Nov 20, 2019 | 11:42 PM
Cutlass89's Avatar
To clarify someone told me to leave one hooked up and only remove the other. Thanks
Old Nov 22, 2019 | 11:37 PM
Cutlass89's Avatar
So my son gave me a pt tools scan tool which I tried to read my stored codes and erase them but I couldnt get it to work right. So I went the next morning to local mechanic who scanned it with his snap on scan tool. Said it had a 1600 series code that had to do with a theft deterrant module, not to worry about it and erased the stored code. My plan is to by a $120.00 scan tool from advance for the next time this may happen.
Old Nov 24, 2019 | 07:04 PM
Cutlass89's Avatar
Well my CEL came back on and my performance tools scanner wont work. Any one know the best budget scanner from advance or autozone?
Old Nov 24, 2019 | 08:39 PM
Cutlass89's Avatar
So ran down to Autozone and had them scan and clear the code, downstream 02 sensor. 10 min job.
whooty
Apr 19, 2023 05:34 PM
bitterbuffaloh
Aug 20, 2016 01:30 AM
TrevorS
11
Jul 11, 2011 03:48 AM
SPACEDOGB
Feb 3, 2011 08:52 PM
overXload
Nov 2, 2009 02:08 AM
