Turbo in a automatic..
I don't understand what you're getting at or what you're even referring to in this post.. Let me rephrase my previous statements then; The transmission is working as intended.
First off whats slipping? I dont understand. And why not change ur exhaust back to your old one or why not get a bigger wastegate? What kinda ECU are you running? How is the boost set so precisely at 8.5 psi?
And lastly ur pushing it, your trans will not hold all that power. When it comes to Toyota's automatic transmissions, power is one thing not towards the top of their list of priorities. Neither is their manual but they still hold a decent amount of power.
___
___
Yes torque converters intentionally slip at stop lights and initial acceleration. However on most modern cars once the RPM has reached a certain speed, the torque converter locks up and and becomes slip-less. This increases fuel economy and power efficiency.
He may not understand all the ins and outs of a torque converter but obviously, when he says it isnt slipping, he means that it is holding under boost and providing good acceleration.
Sorry it's been so long. I have a few updates for you guys and to bump the thread back up. It's not slipping, at all. Firm shifts, yes, but it's not slipping. I'm running about 300 WHP as of now, at 8.5 PSI. I just changed my exhaust from my 2" catback Borla Dual to 3" turboback to Borla Dual and we're having problems because there is too much flow from the manifold. The wastegate cannot keep up. It's spiking to 15 PSI (transmission is shifting at 14 PSI, not getting too hot). Currently I am in the process of getting a hole welded from the side of the descendant manifold, and we are putting on a second 40mm wastegate to allow the boost to properly flow outward. It's absolutely amazing how high the flow is on the manifold. I am aiming for 10 PSI, 330 WHP... transmission has been holding strong at 300 WHP for 4,000 miles.. track, street, whatever. No synthetic oil, normal Toyota (semi-synth?) oil. Tranny cooler... nothing done to the tranny.
you should not have to decrease the size of your exhaust to prevent boost spiking. Also at 8 to 10 psi there is no way a second wastegate should be necessary. Proper manifold design should provide for spike-less boost control. If a high boost application does indeed necessitate a second wastegate, this is something that should be considered in designing to manifold to begin with.
Decreasing exhaust pipe size or sloppily tacking on a second wastegate are both band-aid solutions to the true problem: a manifold with poor flow and design.
scionchicop
Scion tC 2G Forced Induction
27
May 30, 2012 11:56 PM
