Steering wheel audio controls
The tC1, from what I gather, has illuminated audio controls on the steering wheel. The tC2 on the other hand does not or at least mine just do not work. So does the tC2 have illuminated controls or no?
I actually did search, not my first day on a forum.
If you would like to point me to some threads that have already been posted about possibly retrofitting illuminated controls into the tC2 or even making your own setup that would be cool.
I think you missed the part where I said those do answer my question, and by question it means original single question as I did not pluralize the word question. Regardless, thanks for answering my question, I'll figure out the rest on my own here.
I actually thought about asking a tC1 guy about this. I had a tC1 for 6 years and when I got my tC2 I totally forgot if they light up or not. Too bad, but yea you will get used to it.
On the tC1 the AC control LCD was towards the bottom and that illuminated the cabin quite well. The tC2 is dark as hell inside at night time. Yet another one of those cost cutting measures that take away from what the TC should be.
I plan on adding a LED pointing downwards underneath the AC Controls.
The TC1 had a 'cubby' hold light (where you can put sunglasses and CD's, etc; it lit up the interior nicely, i had a nice blue bulb in there.
I did the cup holder thing in the tC1. It was nice, I used 4 color changing LED's, it was badd! But whenever I put a big drink or open the drink holder console the LED's would pop out the LED holder. Can be held in with silicone.
As far as the cubby hole, I was going to put one wide angle LED in there just to illuminate the area. Only thing is I need to figure out what resistor to use because I do not want them to be blinding bright. Luckily my mom's 2010 Rav limited already has these and has some in the foot wells too so I can kind of play with resistors till I get the correct brightness.
Making the steering wheel audio controls illuminate shouldn't be a big issue aside from the fact that nothing on the steering wheel is lit up with the lights on. So I wouldn't have any power source to tap into for illuminations. It is possible the cruise control has a constant hot wire, but that still doesn't help with only turning on with the lights.
I would make a small circuit board using bread board. Problem is trying to get a power source in there. Worst case I would use a constant power source so they would be lit all the time when the car is on.
I'm just not getting this bro. Are the buttons even translucent a little bit? Or is the plus sign, etc just painted on?
Beesh
Jan 9, 2015 06:30 PM
