Subwoofer Install..
I was just coming in to ask what the general scope of work
would be placed into the wiring of a powered subwoofer system in a 2016 Scion tC?
Sticky How To Advanced Search SL (Scion Life)
______________________________
Last edited by MR_LUV; Mar 10, 2019 at 10:58 PM. Reason: Moved to Correct Forum by Administrator
On a purely stock system, about what you'd expect. In its simplest form: Run a power wire to wherever the sub will be placed. Directly tap into or run a LOC off one of the rear channels to splice the audio signal off of (may require a power feed as well). This can be done near the rear speakers or off the line coming from the headunit (google Toyota wiring and a diagram will come up, they're all pretty much the same), then tune the sub. The interior panels comes apart pretty easily as does the headunit. There might be some how-to's around here - I did a full custom install and didn't look.
AzNpNoY74
Scion tC 1G ICE & Interior
15
May 21, 2007 01:37 PM
stirfry
19
Jul 18, 2005 12:12 AM
thelevin8r
May 4, 2005 05:13 PM
