Scion tC 2G Suspension & Handling Coilovers, Shocks, Airbags, Swaybars...
Eibach Sportline Lowering Springs
Old Jan 25, 2018 | 12:56 AM
tc_gang's Avatar
Default Eibach Sportline Lowering Springs
Hi, I was wondering if I need to buy anything other than the lowering springs. I don't want to end up buying them and not have enough parts to complete the install and end up paying more than what I hoped for. This is for a 2011 tC.
Old Jan 27, 2018 | 05:58 AM
bbsciontc's Avatar
Not super familiar with the tC2, but Sportline springs might be a bit much for OEM shocks. They will likely wear out faster. I'd recommend that you go with a sport oriented shock like Tokico or similar.
Besides that, you shouldn't need much. Rent a spring compressor from the auto parts store for free (once returned).
Old Nov 7, 2018 | 05:12 AM
Renike's Avatar
I know it's a late reply but I had them for a bit but of upgraded to coils after a year. I really enjoyed the ride height. Other than the spring you don't need anything else.
Old Nov 9, 2018 | 02:46 PM
drizzoh's Avatar
Old reply but FWIW I had the Sportlines for a few months and they made a ton of noise up front when turning and going over bumps. It was extremely annoying. Ended up getting them RMA'd thru Eibach and then replaced them with the Tein S-Techs. They ride 100% smoother, handle better and the car sits a lot more evenly. 100% recommend the S-Techs over the Sportlines.
Also to answer your original question, unless you want to run ~3 degrees of negative camber in the rear you will need to install adjustable camber arms back there as there is no factory camber adjustment. They're ~$200 for the SPC's I have. Megan also makes a kit.
There are no aftermarket performance shocks available for the tC2. The KYB Excel-G's are the only 'upgrade' option and they're kind of meh. It is a smarter idea to install coilovers on this car as you get new shocks with them and the Tein Basis kit is <$500. This is a good option for people that just want lowering springs as it's cheaper than full-on adjustable coilovers and they can still get adjustable ride height paired with upgraded shocks that can handle the drop and are matched for the spring rate.
tc_gang
Apr 23, 2018 06:00 PM
chrisdiablo
12
Feb 13, 2008 02:30 AM
franktherank
10
Nov 12, 2004 02:22 AM
madpb
Oct 11, 2004 11:50 PM
Al-Truistic
Apr 5, 2004 02:43 AM
