How to remove a nut from a loose stud
^x2, update?
And this is the reason why I went with ARP extended wheel studs and going with hubcentric slip-on spacers. At least it happened on the stud on the actual bolt-on spacer and not the OEM on the hub. Nothing wrong with running bolt-on spacers really as I'm running 25mm H&R for the rear wheels on my '89 Celica but it's one thing more that can break. Jeremydoc if I recall had 2 OEM wheel studs break with the spacer installed, scary.
Ah, forgot to update this!
Just like you said, EOIO3, nut came right off with an impact wrench. Shop I took it to pulled off the wheel and fixed the stud in less than 30 min.
Thanks for the help
Thanks for the help
b18c11
Scion xB 2nd-Gen Wheel & Tire
Apr 4, 2015 07:45 PM
