30K miles maintenance...opinions/help wanted
Old May 1, 2007 | 07:53 PM
slyDbox's Avatar
Default 30K miles maintenance...opinions/help wanted
hey guys...my xb's at 31000 miles...i have had NO problems with the car to date, but i noticed the manual says its time to bring it in,..the only thing is, they want 300$ for:
oil change
air filter
spark plug change
rotate tires
inspect nuts and bolts on chasis and body
replace differential oil
replace manual transmission oil
also, INSPECT a bunch of stuff
now, a couple days ago, my drivers front brake started squeaking and hasnt stopped...i drive in the mountains a lot causing a lot of stress on my brakes...im assuming these need changed--these arent covered under warranty correct?
any recommendations on what services need to be done and what i should reasonably pay
THANKS IN ADVANCE
dan
Old May 1, 2007 | 10:29 PM
jct's Avatar
jct
you should also clean your TB
http://groups.msn.com/Sorensonbrian/...ycleaning.msnw
other then that you got what you need to do
and your correct about the brakes not covered under warranty...
Old May 1, 2007 | 10:34 PM
streetlethalxb's Avatar
^ what he said
and 300 is the average cost.. DIY and save!
Old May 2, 2007 | 12:43 AM
stew32's Avatar
Default Re: 30K miles maintenance...opinions/help wanted
Does the xB have a separate differential case? I thought the differential and transmission were in the same assembly, hence "transaxle"? xB is my first front wheel drive, so pardon my ignorance.
And the owner's manual mentions the differential and transmission oil in the towing section so it's not NEEDED at 30k unless you are. Yeah, probably good to have it done anyway.
30,000 Miles or 36 Months
❑ Replace engine oil and oil filter
❑ Rotate tires
❑ Replace engine air filter
❑ Replace spark plugs (xA and xB)
❑ Tighten drive shaft bolt
❑ Inspect the following:
__ Ball joints and dust covers
__ Brake lines and hoses
__ Brake linings/drums and brake pads/discs
__ Drive shaft boots
__ Engine coolant
__ Exhaust pipes and mountings
__ Front differential oil
Additional Maintenance Items for Special Operating Conditions
Driving in desert or on dirt roads:
❑ Tighten nuts and bolts on chassis
Driving while towing:
❑ Replace front differential oil
❑ Replace manual transmission oil
Old May 2, 2007 | 12:47 AM
vintage42's Avatar
oil change
air filter
spark plug change
rotate tires
now, a couple days ago, my drivers front brake started squeaking...
The usual cost of a dealer 30K service is around $350. You do not say what you can do yourself. Many people can change their motor oil, manual transmission oil, air filter, cabin filter, plugs, and rotate tires. (Tires are supposed to be done every 5K; if your tires have not been rotated, you might consider new tires.)
If you can comfortably do all that, then just have the dealer do the inspection and the brakes. It sounds like you might have gone too long and scored the rotors. If you have an automatic transmission, you might let the dealer do that fluid change.
Old May 2, 2007 | 12:55 AM
06scioxb's Avatar
Team XcelsiA
Team Sushi
i just got back from my dealer like 30 min ago and got the 30k miles maintanace done and they did all you are mentioning and got it done for 241.00 that is including the taxes
STCxB
11
Jan 9, 2015 04:30 PM
TheTripleC
Jan 4, 2015 06:46 PM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
minter66
Dec 15, 2014 01:45 PM
yanges
19
Dec 30, 2003 02:05 AM
