Broken Thermostat housing stud..
Old Sep 14, 2014 | 02:51 PM
2004CSOTP's Avatar
Default Broken Thermostat housing stud..
Hello,
This is my first post on this forum. I have a 2005 Scion xB and have had it since it was new. I'm replacing the water pump which requires the alternator to be removed. I had the great idea of replacing the thermostat at the same time since it is easier to do with the alternator removed. When I put the housing back on, I snapped one of the studs. I have a stud remover, which is a round thing that goes on a half inch drive and grips the stud, but it's too big for this. Is there some technique to getting the broken stud out and does anybody know what size stud I need to replace it? I assume this is not a rare occurrence, and it's probably somewhere on this forum, but I didn't get anything with the search feature. Thanks for your help.
______________________________
Last edited by MR_LUV; Jul 13, 2019 at 06:47 AM. Reason: Moved to Correct Forum by Administrator
Old Sep 15, 2014 | 12:55 AM
2004CSOTP's Avatar
Glad I didn't wait for words of wisdom. PB blaster and a pair of vice grips and it came right out. I couldn't get another stud so I replaced it with a metric bolt from Lowes. All's well now.
Old Jul 12, 2019 | 08:54 PM
mynameisj's Avatar
Default Thank you!
I just want to say thank you! I over tightened that stud and broke it, so I believed I was seriously screwed. I learned that these studs are removable and that I can fix it. AutoZone sells replacement studs so I used one of those. I thank you immensely!
Old Mar 12, 2020 | 07:18 AM
TooCool06TC's Avatar
Originally Posted by 2004CSOTP
Hello,
This is my first post on this forum. I have a 2005 Scion xB and have had it since it was new. I'm replacing the water pump which requires the alternator to be removed. I had the great idea of replacing the thermostat at the same time since it is easier to do with the alternator removed. When I put the housing back on, I snapped one of the studs. I have a stud remover, which is a round thing that goes on a half inch drive and grips the stud, but it's too big for this. Is there some technique to getting the broken stud out and does anybody know what size stud I need to replace it? I assume this is not a rare occurrence, and it's probably somewhere on this forum, but I didn't get anything with the Search feature. Thanks for your help.
Remove the heat shield from the headers for more leverage and remove your oil dip stick.
Then grab some small Vice Grips and turn counter clockwise that stud it should come out in matter minutes
______
Sciota
30
Jun 9, 2025 11:29 PM
Sgtusmc98
14
Feb 12, 2023 01:56 PM
jabbott28
Aug 21, 2019 05:17 PM
MightyP
Scion tC 2G Wheel & Tire
24
Feb 19, 2012 08:58 PM
boxlver
24
Sep 9, 2005 01:27 PM
