engine swaps possible for the box? (edited: need help)
Old Mar 20, 2007 | 03:21 PM
stangdude22's Avatar
Originally Posted by mynameisphunk
OK, no, I don't know this for a fact. But why would the second generation xB be even roughly based on the first generation xB when the drivetrain is completely different, along with the size of the vehicle? Does the tC drivetrain drop directly into a first gen xB? Does a Camry 2.4L drop directly into a first gen xB? So why would the second gen xB's 2.4L drop directly into the first gen? I would say it's 99% more likely that the 2.4's will swap directly from Camry to tC to second gen xB than that the second gen xB's motor will drop directly into a first gen.
And no, I wouldn't think that a Montana and a Regal are different drivetrain setups - everything under God's green earth has had the GM 3800 in it over the years, it seems.
So motor mounts? Same on the 2.4L as the 1.5? can you even shoehorn a 2.4L into the engine bay of a first gen xB with serious firewall modifications?
Yeah I remember hearing that it uses the same engine as the TC. Anyone ever attemped that install?
And yes, the 3800 has been in every Gm car ever made it seems like...
Old Mar 20, 2007 | 08:18 PM
Sly_dawg19's Avatar
everybody knows that renaults f1 engines are 100% drop in and plug and play the 1st gen xb..
GOSH!
Old Mar 20, 2007 | 08:26 PM
Yeah, and with a little bit of massaging the v16 out of the Cadillac 16 prototype fits like a glove. The only real prob is finding the engine.
Suprised you people havnt heard of this...
Old Mar 21, 2007 | 01:11 PM
BoogieQ's Avatar
Just because the car is new doesn't mean the underlying setup isn't almost identical. They change many things, sure, but they keep a lot of things the same for cost savings. I could be wrong but until I can look into the engine bay I'm trying to stay open minded.
Can the 2.4 from the TC fit in the xB? Sure. Can you take the current TC setup and put it right into a current gen xB? Not directly..... Thus when the xB DOES come out with that drivetrain, they will have figured it out. If the engine bays are the same and they change out the cradle and engine mounting setups, you can get those parts and the drivetrain from a TC... bling.
I don't know why you all are trying to shoot down a GOOD thing if they keep things similar for an 'easy' engine swap. But whatever. I like to think there will be a good option to retrofit a TC engine to a first gen xB using whatever mounts/cradle/axle/axlehub setup they choose to use. What if all you have to do is get custom driveshafts made? Cheap price to pay to get the 2.4 in there and make these cars more fun.
ANYWAY... we will see I guess.
Old Mar 21, 2007 | 03:58 PM
Sly_dawg19's Avatar
im all for it, then i could have a 2.4 in my xA make it easier on my pocket to 450 bhp
Old Mar 21, 2007 | 05:00 PM
mynameisphunk's Avatar
Where I think your error in judgment is is that you're assuming they'd base the car on the current xB and figure out how to fit the 2.4 in there. Why not base the car on the Camry platform, or the tC platform, or something else with the 2.4 already in it? The cost savings are still there by platform sharing, and it's obvious that the new xB is larger in almost all dimensions (including vastly higher curb weight)...I will basically eat my shorts if the 2nd-gen xB's 2.4 is any easier to swap into a 1st gen than a tC or Camry 2.4 is. Of all the cars in the stable that they could base the 2nd-gen xB on, it appears that the Echo/xA/xB platform is about the least likely that they used based on drivetrain, size, weight, etc.... I would still say that a 2.4 swap out of the 2nd-gen will be a completely, completely custom job.
Old Mar 21, 2007 | 05:22 PM
overall length over a foot longer, wheelbase 4" longer, almost 3" wider track, bigger brakes all around, motor out of the tC/Camry, and curb weight up over 600lbs (more than 20% increase!) over the current model. I really don't see how much of the car could possibly be based on the current car.
Old Mar 21, 2007 | 06:00 PM
i can forsee alot of people doing a brake swap as long as it is compatible
11" in the front and 10" in the back, right?
Old Mar 21, 2007 | 07:13 PM
roughly that, yes. I still think spindles and everything will be different, but anything that will swap would be great.
Old Mar 21, 2007 | 07:15 PM
rockbrawler884's Avatar
I thought I read somewhere on this site about someone who put a 2az-fe in his box.
Old Mar 21, 2007 | 07:21 PM
BoogieQ's Avatar
Alright guys, I'll let it go. I'm glad nobody wants to consider it being easier. I'm glad you all are discussing how a bike engine might be used....
Yeah... woot. Nevermind.
Old Mar 21, 2007 | 08:08 PM
I'm being realistic. It is unlikely at best that this will be an easy swap. Of course, with enough money, anyone can do anything.
Old Mar 21, 2007 | 08:14 PM
Its not that no one wants to consider it being easier, it just from the info that we are getting its looking to be a completely different engine.
A bike engine would deffinetly be harder regardless of what the do with the engine, lol
Old Mar 21, 2007 | 10:06 PM
wanachat15's Avatar
so guys? overall what you think i should do? tc engine sounds cool but no drive train? that sucks.
------tom
Old Mar 21, 2007 | 10:19 PM
you never said why you want to change. Blown engine, more power, something laying around?
For more power, it would be cheaper to go the turbo route and would probably net more HP
Old Mar 21, 2007 | 11:38 PM
Super-Stormtrooper07's Avatar
Does anyone know, can a Corrolla/ Matrix XRS(2003-6) - the VVTL-i 1.8L engine , work in either a xA or xB (that engine works off the 6-speed manual) - I dont know what engine model # it is ? Might need a new transmission ??
Old Mar 23, 2007 | 06:03 AM
Gardiner's Avatar
N.G.S.O.
Originally Posted by stangdude22
Originally Posted by TIGRIS
nice, the 3gte? mr2 turbo would be sweet for a rwd motor. I have some pics of a guy who's putting a v8 in his, I'll post up nextweek.
v8 in a Xb?!? LSx, LTx or Mustang engine?
I always thought it would be cool to rip out the back and drop a Caddy Northstar setup back there. Just lock down the steering and make the box a rear wheel drive with 300 plus hp!
Old Mar 23, 2007 | 09:08 PM
Winter's Avatar
i've go a couple freinds who think i should swap my block out with a rottery block from the RX7's and then route in a rearwheel drive train all the way to the back. i told them it wouldn't fit and they said "well if he cut this out and that out and this out"... oh and they also sugjested an SRT4 aswell and make it a rear wheel drive...
*sarcasticly said* leave to a couple drifters to give you ideas of performance upgrades...
Old Mar 24, 2007 | 10:31 AM
wanachat15's Avatar
i wanted to drop a new motor for more power and thought a bike motor would sound killer and have plenty of power. but is our box really a porky. how bout a VW rabbit motor? or GTI.
and for turbo, yea i consider it, but anything else that would make it more powerful?. like rebuild and F/I?
---tom
Old Mar 24, 2007 | 02:29 PM
The Rabbit motor is a 2.5 inline 5, and the 2.0T from the GTI isn't going to fit either. Man...do you know how many thousands of dollars in parts, labor, fab work, getting past the immobilizer and misc. other electronics in the engine to even get it to run, much less getting it to fit in the tiny engine bay we have to work with?
You'd be way better off stripping every piece of interior panel, sound deadening, etc... out of the box to shed a hundred pounds or two. Bike motors are also not the pinnacle of emissions...there's no way you'll pass emissions (if you have them there) with a bike motor in the car. A hayabusa motor would be amazing, though, if you could pull it off.
