How do I remove the Battery?
I'm a total car newbie and i need help in removing the Scion battery. I can't remember if I remove the positive or the negative first.
And in what order do I reconnect the terminals? Do I need rubber gloves or anything like that? Are there any screws holding the clamps in place?
__________________
__________________
alright... you got two nuts holding the clamps on... you take the negative off first and set it aside. then take the positve off and set it aside. then you loosen the two nuts on the bracket, from the top of the bracket push away from the battery and pull up.. there are little hooks at the bottom that hook into holes in the body. set the bracket aside and pull the battery out. put the positve on first then the negative.. i don't really think it matters, but that's the way i do it. you don't need gloves, it won't shock you.
Don't ground out the positive side when taking it off... I did this on my Stealth and it sparked pretty good.
Also don't install it backwards, bad idea too (I've seen too many people try this before).
____
____
Originally Posted by supitsmark
and it's okay to use those tools on the clamps without being shocked?
Italiangurl
Scion tC 1G ICE & Interior
Apr 3, 2007 10:35 PM
