Perrin Pulley Fits
I'm sorry I took so long to get back to you guys, but It was less than the 3 months that I waited for the damn thing
. It took me 30 minutes to put it on my Xb. All I can say is
Sweet. The car revs 75-100% faster than it did with the stock pulley. First and second gear are over before you know it. The car pulls much harder than it did before. My only problem is now my clutch is slipping like a **** when I get on it. I guess I'm gonna have to do that clutch and flywheel sooner than I thought. All and all I give it a big thumbs up for anyone who is looking for alittle more acceleration and better throttle response out of their Xb or Xa. I'll put pics of it installed into my links later on today or tomorrow.
whats the easiest way to put it on and such
Getting to it is the hardest part because you have to remove the plastic under the car, then the 2 belts. After that it's just one bolt. Then do everything in reverse. I think I have a few pictures in stages but I'll have to check my camera.
THANKS MUNCH!
I guess its time to get one then. I appreciate the effort and still wanting to go w/ the pulley after the whole fiasco.
Good thing I have access to a lift!
Originally Posted by squirrel
THANKS MUNCH!
Do you think this part would compliment my automatic? I'm thinking about getting the lightened pulley and flywheel. Does anyone think that would be a bad idea with an automatic tranny? Could I do damage to it? Would I see a performace increase? Opinions/ideas anyone?
Heh, I must have been confused about that flywheel thing. I've worked on mostly American rw cars until this car; I didn't know it was so different. Here is the flywheel that I'm thinking of:
http://www.carcarecouncil.org/Auto_T...lexplate.shtml
Description: The flywheel for most automatic transmissions/transaxles is simply a stamped-steel disc with a ring gear located at the outer edge for engagement with the starter's pinion gear. With this type of flywheel, the torque converter has no ring gear. Some cars use a more modest flywheel known as a flexplate, which is all that's needed because the torque converter itself has a ring gear located on its outer edge.
Purpose: The flywheel, or flexplate, mounts to the engine's crankshaft and also serves as a mounting location for the torque converter. Consequently, the flywheel or flexplate transmits engine torque to the torque converter housing. The flywheel's ring gear also serves as an engagement point for the pinion of the starter motor when cranking the engine. Because of the lightweight design of the flywheel or flexplate, it does not help to smooth out power pulses from the engine like the flywheel does on a car with a manual transmission. On cars with automatic transmissions, the torque converter provides this function.
