Perrin Pulley Fits
Old Feb 1, 2005 | 07:07 PM
  #41
superjeer's Avatar
Originally Posted by camoboXb
Someone needs to do a write up for the "tech" section
Hmmm who? who could do such a thing?
Oh, not me. Mikochu must.
Old Feb 2, 2005 | 12:13 AM
  #42
dgHotLava's Avatar
someone here needs to take good pics when doing theirs.
and add a decent write up.
Mikochu will then add it to the tech section...
Old Feb 2, 2005 | 12:26 AM
  #43
mikochu's Avatar
Yeah, someone else do the how-to. I don't know when I'm going to be able to purchase the Perrin lightened pulley. I'm trying to save up for a new mp3 player and wheels...
Old Feb 4, 2005 | 08:28 PM
  #44
Skaterjoes's Avatar
Aaaaargh, got my pulley yesterday, jack up the car last night, removed the plastic underneath the car and then realized that I had no clue on how to remove the belts?????, Then when I took my rachet to the bolt on the pulleyall it did was rotate it.... Obviously doin somethin wrong, does anyone have any advice for removing the belts and oem pulley? Thanx
Old Feb 4, 2005 | 09:06 PM
  #45
Munch's Avatar
You have to loosen the alternator bolts and rotae the alternator down to loosen that belt. For the power steering belt, I just stuck a big screwdriver between the belt and the pulley, put a ratchet on the crank pulley and turned it while prying the belt to the side and rotated the crak bolt until it came off. Nice an easy. For the crank bolt if you don't have air tools I feel sorry for you. Just put the car in gear and then give it a try. If the wheels spin have someone hold the wheel for you and try to break it loose quick. That's all the help I can provide without doing it myself. I hope it helps you out.
Old Feb 4, 2005 | 09:20 PM
  #46
Skaterjoes's Avatar
Thanks Munch... I wish I had air tools! But I'll give it a try w/ hand tools! Any additional suggestions would be great! I'll let you guys know how it goes.
Old Feb 4, 2005 | 09:29 PM
  #47
Munch's Avatar
I gave you my trick for the power steering belt. That's all I got
Old Feb 4, 2005 | 11:01 PM
  #48
dgHotLava's Avatar
if its in gear (like you said) just have them step on the breaks....
Old Feb 4, 2005 | 11:09 PM
  #49
Skaterjoes's Avatar
What do the brakes have to do w/ the engine turning over? Aren't they independant of the engine crank turning?
Old Feb 4, 2005 | 11:16 PM
  #50
dgHotLava's Avatar
engine --turns-- transmission
transmission --turns-- wheels
brakes --stop-- wheels can you see the connection???
Old Feb 4, 2005 | 11:29 PM
  #51
Skaterjoes's Avatar
AAAHHHHHHhhhhhhhh. ...... I see says the blind young man... Thanks fr the tips guys, I'm gonna try and get that thing done this weekend. Can't wait to see what happens!
Old Feb 5, 2005 | 12:27 AM
  #52
Munch's Avatar
Yup Yup
Old Feb 5, 2005 | 12:43 AM
  #53
dgHotLava's Avatar
just figured that if you had a tire spinning, it was most likely to be the one you would be working by.
having someone step on the brakes (and in gear) would keep them out of your way....
Old Feb 5, 2005 | 05:11 PM
  #54
Derk-xB's Avatar
does anything bad happen if you turn the crank the wrong way? (either tightening or loosening the pulley)
Old Feb 5, 2005 | 07:02 PM
  #55
Skaterjoes's Avatar
Well took the hand tools to it and guess what, no luck. first of all when I loosened the 2 alternator bolts to move the alternater, it would not budge... then I took your advice, putting the car in gear and stepping on the brakes, but what do you know, the pulley still spins, so now i guess I'll just have to take it to a shop to get it done
Old Feb 5, 2005 | 07:04 PM
  #56
mikochu's Avatar
Use a screwdriver and lodge it into the stock pulley so you can untighten the bolt...
Old Feb 5, 2005 | 11:38 PM
  #57
VIET_BOX's Avatar
Just installed the pulley this morning and i gotta say this is a must have for your xa or xb. car revs so much faster now
Old Feb 5, 2005 | 11:44 PM
  #58
dgHotLava's Avatar
is that the same as loosen????
j/p
Old Feb 6, 2005 | 04:27 PM
  #59
Munch's Avatar
Yup
Old Feb 7, 2005 | 05:14 PM
  #60
Skaterjoes's Avatar
I feel like a moron! Ran out of time to inatall my pulley this weekend cause I had to go to work & I couldn't figure out how to take the pulley off. Mikochu's suggestion to use the screwdriver came just after I'd already lowered the car and goin to work. I guess I'll have to give it another go. Hopefully Someone can do a How-to in the tech section so morons like me have a baby proof play by play on how to get this thing on. From what I'm reading, it seems like everyone is very happy w/ it.
