xA codes P0441, P0455, where is the Purge Valve?
Hi...I am getting codes P0441 and P0455 on a 06 xA with a check engine light. I bought a new STANT gas cap, installed it today but haven't pulled the battery cable to reset, I have no OBD scanner. I was told it may also be the purge valve, I see many for sale on e-bay but I don't know where the valve is located. I think it is in the engine compartment, can anyone advise me here? I certainly hope it is not canister problems, maybe it is just the cap. Will pull the battery tomorrow. I sure wish I knew where the purge valve is located.
Thanks!!!
Thanks!!!
Could be as simple as corroded electrical contacts. If you find the valves, disconnect the electrical connector, soak/spray in WD40 and plug back in a few times to wipe any corrosion off and see what happens before investing in new valves.
Remember the old nintendo's - they had the same problem
IFeelYourPain
Jul 22, 2017 07:02 PM
xatuner
Jan 5, 2013 09:11 PM
the_butcher
Sep 16, 2011 01:23 AM
feldy
Mar 12, 2010 02:48 PM
