xA Throttle body..
Hi, I'm trying to do the 1ZZ Throttle Body swap, already got the TB, but I'm really confused on the vacuum line part. What do I do exactly about that?
I saw one guy with an xA do it with an OBX spacer and nothing back from him. but I saw he had a hose around the Evap on the top of the tp, can I just get a hose that will fit onto the Evap on top of the TB?
Sorry I am really confused.
Sticky How To Advanced Search SL (Scion Life)
______________________________
Last edited by MR_LUV; May 11, 2021 at 10:11 AM. Reason: Moved to Correct Forum by Administrator
I have to ask why...proven to be both a PITA, as you're discovering, with little to no benefit on a stock engine. The stock 1NZ throttle body has been proven not to be an impediment to making power and flows plenty.
There were, at one point, plenty of 'How-To's' on this one and everyone seemed to do it a little different.
I kicked around the swap versus just having the stock throttle bottle bored with a larger plate that was knife-edged...went with the bored throttle body in order to avoid all of the installation issues. Throttle body is still sitting in my basement connected to a WeaponR sheet metal intake manifold that I may get around to installing at some point.
Eventually I'll be installing a 2ZZ throttle body...connected to a 2ZZ motor and 'front-ended' with an axial flow rotary exhaust.
Wow that's awesome!
Would you consider contacting me via PM on the TB or Intake Manifold I am interested?
____
____
Last edited by MR_LUV; May 15, 2021 at 04:03 AM. Reason: WTB Not Permitted in Tech Forum Per Forum Rules
Blacktoast
Apr 11, 2007 01:17 AM
LavaScionSouthernArizona
Aug 31, 2004 11:33 PM
